Benchmark DAC2 HGC does anyone run one?
Benchmark has a special trade in on your old DAC.
10 hours left...
Thoughts?
  • footwedge
    footwedge Posts: 475
    edited March 2016
    deleted post
  • [Deleted User]
    [Deleted User] Posts: 10,716
    edited March 2016
    I don't work for them or anything.
    Sorry if I offend...
    did @mikeyb128 every get his? :*
    search function did yield some results :#
  • mikeyb128
    mikeyb128 Posts: 2,885
    I've had mine since around Christmas, And so does @steveinaz if I recall correctly. What would you like to know?
    2 channel:
    Theater:
  • [Deleted User]
    edited March 2016
    well I'm at a crossroads trying to integrate my HT and 2 channel and
    it seems to be holding me back. Love the sound for the most part
    and for movies I'm good but... nice soundstage but for 3-d sound...
    I've got the Benchmark amp and was thinking the DAC would be
    a no brainer as a "pre" and just split the analog and digital worlds.
    Would you describe the sound as digital or lean or warm of phatt?
  • [Deleted User]
    Anyway, I did want to get out there that their
    trade-in "special" was running again if someone was on the
    fence.
  • mikeyb128
    I describe mine as warm, very clean and neutral, I really liked what it did in my system. I found it to have a very wide and deep sound stage with a lot of detail. It was a major step up from the benchmark dac1 pre which was a little more forward. For the price of the dac2 it is a feature packed unit, and performs really well in all aspects. The DAC being the strongest point of its features. I did notice better sound through xlr than through RCA, so I recommend using those. And it uses 4 ESS 32 bit DAC sabre chips per channel on the xlr output if I recall correctly. Also you can crack it open and adjust the gain for the outputs using little jumpers. It does have home theater bypass, and from what I noticed it seems to automatically adjust to the correct gain with the volume knob (does not have fixed and variable switch on the back like dac1).
    I use mine as a stand alone DAC right now, but it's good to know it has a pre amp in case I need it as a back up. I really feel the benchmark doesn't get as much love as it should in the audiophile world. They were the one of the first ones in the DAC game from what I know.
    Add a power cord and nice cables to it and sit back and enjoy. I had many people surprised with the sound that comes from that small little box. I would say go for it. Mine did require a lengthy break in period though.
    2 channel:
    Theater:
  • mikeyb128
    As far as your comment on digital... I have an older buddy who is a vinyl addict, anolog psycho. He has more money into his tt than my entire system and home theater combined. He hated "digital nasties" and refuses any computer listening. He really liked what the benchmark brought to the table when playing from my computer, so I take that as a compliment. No it's not super anolog sounding, but I find it takes that digital edge off the music, and really does well with overly hot recordings.
    2 channel:
    Theater:
    heiney9 Posts: 25,675
    How can something be warm and neutral?
  • [Deleted User]
    Thanks @mikeyb128! That was what I was looking for. :)
    Tip of the cap.
  • [Deleted User]
    heiney9 wrote: »
  • mikeyb128
    edited March 2016
    heiney9 wrote: »
    Ok I'm not the best at explaning what I hear sometimes. And I'm certainly not an audiophile, I'm also fairly new to the 2 channel game, cut me some slack man. :neutral:
    2 channel:
    Theater:
    I will, was just bustin' you balls............... :p
  • steveinaz
    steveinaz Posts: 19,546
    I have the Benchmark DAC2 "L" which is the HGC minus the headphone section. I got the trade-up credit of $800 from my DAC/PRE. Love the DAC2 version. They now have 2 sets of analog inputs and 2 sets of outputs. Very smooth--love it. I use mine as my preamp; DEAD quiet and supremely neutral. The new DAC2's have a number of other improvements as well, see the BM website for details.
  • steveinaz
    heiney9 wrote: »
    He's probably trying to relate that the new DAC2 is not as "sterile" sounding as the DAC1's were. I agree whole heartedly. The sound has a touch more "body/solidity" to it.
  • [Deleted User]
    Thanks @steveinaz sounds better every minute!
  • steveinaz
    edited March 2016
    You can get a few variations; The DAC2 HGC, DAC2 L, DAC2 DX and DAC2 D--they all feature the Hybrid Gain Control 32bit volume setup.
    I've never been a headphone guy, so the "L" saved me $200. The "DX" is new and features the much missed XLR digital input of early DAC1's.
  • mikeyb128
    edited March 2016
    heiney9 wrote: »
    Thanks buddy.. You had me a little worried there :smile:
    2 channel:
    Theater:
  • steveinaz
    If it means anything, Stereophile's comments were: "The DAC2's measured performace is superb."
  • [Deleted User]
    I subscribe. XMas gift. :)
    SCompRacer Posts: 9,391
    edited March 2016
    mikeyb128 wrote: »
    It has four ESS Sabre 9018 DAC chips with four channels allocated to each side of a stereo signal. ;)
    Each 9018 has 8 individual channels which can make an 8 channel DAC or you can join inputs/outputs together. Some manufacturers will use a couple of DAC's for headphone out. Oppo did that. The DAC can be internally remapped via firmware.
    This illustration shows what goes on with a single 9018 chip with DSD inputs combined and internal remap. Note we have four DAC's for channel A and four for B.
    biiidsddefault.png?w=893&h=608
    This one with PCM and inputs combined, no internal remap. Note we still have 4 DAC's per channel.
    biiii2sdefault.png?w=893&h=608
    Changing the Quantizer in the DAC's firmware alters the output config.
    Quantizer / Input Channels Used /Output
    6-bit 8 (All) 8×1 – 8-Channel
    7-bit 8 (All) 8×1 – 8-Channel
    8-bit 4 (#1,#2,#5,#6) 4×2 – 4-Channel
    9-bit 2 (#1 and #2) 2×4 -Stereo
    Even more than you would possibly want to know. ;) These details were extracted from a diyaudio thread by the ESS Sabre lead designer. It contained info beyond that in the data sheet.
    https://hifiduino.wordpress.com/sabre32/
  • [Deleted User]
    I did read that about the Oppo somewhere (maybe here)
    "Quad 32-bit balanced D/A Conversion System"
    so if I'm following, it depends on the firmware?
    edited March 2016
    The DAC chips firmware determines the DAC's configuration. The manufacturer sets the firmware to fit their design parameters based on the data sheet ESS Sabre furnishes. Firmware settings can be fixed with either manual dipswitches and onboard microcontroller or with I2C serial communication and external microcontroller.
    Just a guess, but Benchmark could use two DAC chips for PCM output and two for DSD output. Depending on input sensed the DAC chip can be muted, firmware settings changed, DAC unmuted and ready to go in a second.
    Firmware can also be optimized per input. PCM and DSD like different settings. However manufacturers are unlikely to allow customers to change the settings as they can lose the rabbit they were hunting and get lost themselves.
    An illustration of most of the settings in an ESS 9018 DAC chip. Without knowing what each do, one could get a poor sounding or non functioning DAC. Missing in this illustration is the OSF or oversampling filter. It can be turned on and off.
    lcde8a1a8e7a4bab.jpg?w=595
  • [Deleted User]
    It will take me a while to drink this in. :#
    Thanks!
  • FTGV
    FTGV Posts: 3,650
    edited March 2016
    Thanks!
    I think what Rich (Scomp) is saying is that unit uses a very high performance dac chip.They also paid attention to the important analog section by incorporating some very good LME49860 Opamps.
  • kevhed72
    kevhed72 Posts: 5,218
    SteveMichael should I click your links and enter my information? This sounds fascinating...
    VR3 Posts: 29,733
    I hope the trade in is still going on
  • skrol
    skrol Posts: 3,493
    I have a DAC1 that has been a very nice entrypoint into external DACs. Now that I have had it a while, I wouldn't mind upgrading.
    Stan
    Main 2ch:
    HT:
    Other stuff:
