Cover me...I'm going in!
I'm looking to get a TT but I don't wanna go nuts. I've been researching and these are the three I'm considering:
TEAC TN-300
Music Hall usb-1
Audio-Technica AT-LP120-USB
Does anyone have any experience with any of the above? Would like to hear feedback or suggestions. I'm not looking to break the bank, just want to fool around with vinyl.
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
  • honestaquarian
    honestaquarian Posts: 3,259
    Is the Audio Technica the one that looks just like a Technics SL-1200?
    Also I see that two of them are USB tables.
    Is there a particular reason for this?
  • ROHfan
    ROHfan Posts: 1,014
    edited March 2016
    Yes on the Audio Technica, and for the USB, no particular reason except that they happen to have that functionality. I won't be using it, however.
  • [Deleted User]
    [Deleted User] Posts: 10,716
    first of all, don't do it.
  • ROHfan
    ROHfan Posts: 1,014
    Anything else?
  • Nightfall
    Nightfall Posts: 10,083
    A good working vintage table in your price range would be better than what you're looking at IMO.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • [Deleted User]
    I've looked at this 5 ways from sunday and wish I had kept notes.
    In the end, I put my money somewhere else. (I have a @Rick88 table)
    The Audio-Technica AT-LP120-USB was a contender but if you want
    more or less P-n-P look elsewhere I speculate based on reviews.
    If you don't fear the setup, it seems the way to go in the price range.
    ($200)
  • ROHfan
    ROHfan Posts: 1,014
    ($200)
    Now yer helpin' me! :)
    That Teac got almost no negative reviews anywhere and the cherry version looks sexy as hell. The AT looks like a toy.
  • ROHfan
    ROHfan Posts: 1,014
    Nightfall wrote: »
    I wouldn't know where to begin. Can you recommend a few? There are lots of TTs on my local Craigslist so it's worth a shot.
    SCompRacer Posts: 9,128
    Vinyl is just a passing fad....mine has lasted 50 years... :smile:
    With used tables you'll want to verify they hold proper speed. That would require a strobe and hypnotic bars that spin on the platter. Some platter mats had the strobe lines on the inner label indent. Instead of strobe, an incandescent light bulb (60Hz light bulb) can be used. Frequency can vary depending on mains frequency.
    The arm should pass the swing and bob test. Neutral balance the arm with stylus guard on. LIGHTLY push the arm, it should swing back and forth on a horizontal and vertical plane without binding. If it binds you have arm bearing problems.
  • [Deleted User]
    I'm told you can fix the "pitch adjuster thingy" by cleaning it.
    I'm going to find out right now as I've been meaning to do this
    with the Dual table sitting in the basement...
  • Nightfall
    @mhardy6647 helped me pick my table from the multitude that were available on my Craigslist. What city Craigslist do you look through?
    afterburnt wrote: »
    msg Posts: 10,479
    ROHfan wrote: »
    LOLOL
    ROFLMAO
    LOLOL
    B)
  • ROHfan
    ROHfan Posts: 1,014
    Nightfall wrote: »
    Long Island.
  • Nightfall
    edited March 2016
    https://longisland.craigslist.org/ele/5489028858.html - Pioneer PL-570
    https://longisland.craigslist.org/ele/5468212825.html - Dual 1229Q w/ Shure V15 type III cart
    https://longisland.craigslist.org/ele/5479654316.html - Technics SL1200 MK2
    These all caught my eye. No idea which would be the best or if their prices are fair but I can promise you that they'd all be better than the Teac. Do some price research first. The Shure V15 on the Dual is a very nice cart. The Technics is probably about the most popular turntable on the planet. Don't know much about the Pioneer but perhaps somebody with more vintage TT knowledge will chime in.
    The guy with the Dual says needs to be serviced first. Does that mean it has issues or is he just recommending that it be done? Question to ask.
    The Technics looks like the safest bet after looking at the posts. I'm not sure which Dynavector that is but they make some good carts.
    Could be this one -
    http://www.musicdirect.com/p-6977-dynavector-10x5-mc-phono-cartridge.aspx?utm_source=googlepepla&utm_medium=adwords&id=152906042690&gclid=CPbQp7OBxMsCFYGFaQod5rUMEg
    Which is a $650 cartridge.
    afterburnt wrote: »
  • Nightfall
    edited March 2016
    Do you have a phono preamp or one built into whatever equipment you are using?
    afterburnt wrote: »
  • Nightfall
    msg wrote: »
    ROHfan wrote: »
    LOLOL
    ROFLMAO
    LOLOL
    B)
    Truth. I spent $279 last trip to the record store. I will be eating Ramen this pay period. ;)
    afterburnt wrote: »
  • [Deleted User]
    "I spent $279 last trip to the record store." Oh my. :)
  • Nightfall
    edited March 2016
    I know. Wish You Were Here was $32, Hemispheres was $30, 100 outer sleeves and 100 MoFi inner sleeves was $60... oops already up to $120.
    I do search my two local thrift stores for rednedtugent dollar finds but all they ever have, most of the time, is Barbara Streisand and Gospel records.
    afterburnt wrote: »
  • lightman1
    lightman1 Posts: 10,797
    Nightfall wrote: »
    msg wrote: »
    ROHfan wrote: »
    LOLOL
    ROFLMAO
    LOLOL
    B)
    Dude's got it bad. Real bad....
  • [Deleted User]
    edited March 2016
    so what use guys are sayin' is this is @mhardy6647 's fault.
    I'm in the clear >:)
    Well, I tried to warn @ROHfan off. o:)
  • [Deleted User]
    Just hooked up the Rotel (not Dual) from the basement. up and spinning after some cleaning. Got the pitch stable. Still think that either the needle needs replacing or
    re-aligning... Still, it sounds good. :)
    msg Posts: 10,479
    edited March 2016
    Vinyl can be a lot of fun, man, and completely and absolutely consuming. I'm interested to follow your progress to see what you end up getting into. And also to see just how hooked you get. Took me two tries. First time didn't take.
    Lots of great resources here to guide you along the way, and, as I'm sure you know, all of us enablers B)
    Just something about beautiful noise coming from the mesmerizing spinny thing...
  • ROHfan
    ROHfan Posts: 1,014
    Nightfall wrote: »
    The TTs I was looking at had built-in preamps, but no, I don't have the option on my receiver.
  • StevieB
    StevieB Posts: 257
    edited March 2016
    Nightfall wrote: »
    Down in Florida I would add Ray Conniff and Herb Alpert to the list. I'm absolutely amazed how many albums Streisand has sold.
    McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
  • ROHfan
    ROHfan Posts: 1,014
    Nightfall wrote: »
    Could be this one -
    The Techniques is probably the only one I'd consider. And it did catch my eye yesterday. Got to research his price, though.
  • ROHfan
    ROHfan Posts: 1,014
    msg wrote: »
    ROHfan wrote: »
    LOLOL
    ROFLMAO
    LOLOL
    B)
    It's gonna be different this time. I can control it. I promise. This is the last piece of audio equipment I'll ever need. :)
  • chumlie
    chumlie Posts: 8,658
    Quite satisfied with mine, Easy setup, No issues in over a year and sounds pretty good to me.
    heiney9 Posts: 25,530
    What's the appeal of going so low budget? You aren't going to get the enjoyment out of it by staying at the very bottom, IMO.
    Perhaps we have a different set of criteria however.
    What are you trying to do? If you are trying to get the vinyl experience, you won't get close with what you've posted so far.
    Just my .02c. I apologize in advance if my statements seem blunt, don't mean to be, just saying like I see it.
    P.s. I'm not suggesting you spend $2K, but atleast look at some units that require an external phono pre-amp. I can't imagine the one's built in are all that great.
  • ROHfan
    ROHfan Posts: 1,014
    heiney9 wrote: »
    With the three I mentioned you have the option of using the on-board preamp OR switching it over to use an external pre.
  • cstibitz
    cstibitz Posts: 14
    I've been looking at Rega rp1, Pro-ject Carbon Debut, and U-turn upgrade. All seem to be entry level audiophile quality for around $400 or less. Large majority of reviews I read were pretty good.
