Polk SDA SRS ohm
I just acquired a set of Polk SDA SRS Signature Series speakers. I am trying to find out if these are 4ohm or 8ohm? They are the Blade/Blade Interconnect cable type and have the silver tweeters Left speaker (Serial# L SDA-SRS 3245). I am running on a Pioneer Spec 2 amp that has the selector switch rear of amp for 4ohm or 8 ohm. I do not want to damage my amp or/ the speakers. Thanks for any replies in advance :smile:
Best Answer
    F1nut Posts: 52,101
    Answer ✓
    Sherwin1 wrote: »
    yes, thanks! do you mind if i ask how you could tell..for my own knowledge gathering.
    Published specs.
Answers
