Need Help
boston1450
boston1450 Posts: 7,668
edited March 2016 in 2 Channel Audio
Will a Parasound 750a be a good amp for my center speaker. Can i run it mono ? 250wpc i think ? Cs1000p is my center speaker. I have a amp for my fronts already. Any help would be appreciated
  • boston1450
    edited March 2016
    Using a Yamaha rxv2600 @ 130wpc now & would i benifit by adding a amp to center speaker ? (I asked this question already on FS section-sorry to be asking twice)
  • boston1450
    If i use it mono & run just one cable from amp-to-speaker would this make it better quality power ? cuv3ipt5bxsy.png
  • drumminman
    drumminman Posts: 3,396
    Why not try it and see what you think? If it's designed to run in mono and your avr can adjust the volume on each channel separately it could improve your home theater audio.
  • boston1450
    I got to take a break with my mind before i go into circles. Thank you
