HDMI/RCA/Coaxial port dust covers...
EndersShadow
EndersShadow Posts: 17,715
edited March 2016 in Electronics
I'm looking to buy some covers/noise blockers for my Denon X4100w.
I am aware of these Audioquest noiseblockers but not sure if you can use them for coaxial/composite/component inputs or just RCA's? Also I'd need ~~40 by my count for all the unused RCA/Composite/Component/Coaxial ports so the Audioquest ones get pricey quick.
I also found some HDMI port plugs but didnt know if there was a better product out there or not. Looking to basically cover all the unused ports to keep them looking nice and dust free....
Might use some of the cheap silicone ones for my computer and htpc as well just to keep the dust out...
  • Mikey081057
    Mikey081057 Posts: 7,127
    Garage | Polk Monitor 5B's
    Yeah those aren't much cheaper than the Audioquest ones TBH...
    Anyone have some suggestions or am I alone on this one lol..
    pitdogg2 Posts: 27,174
    Dan find the seller 8audio on eBay may not be much cheaper but worth a look. Also look at essentra company I sent you a while back thought I seen them there also
  • deucekazoo
    deucekazoo Posts: 146
    Do you need noise blocking ones or do you just want to cover the connector to protect it from dust/dirt.
    I use the vinyl caps that are used for vacuum ports. You can get them at any auto parts store or hardware store. These do the job and are cheap.
    http://www.jegs.com/i/Milodon/697/41150/10002/-1?CAWELAID=1710524736&CAGPSPN=pla&catargetid=230006180003463476&cadevice=c&gclid=CJDIjpyAqssCFQepaQodcIkB3g
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
    Working on getting SDAs
    edited March 2016
    Ivan:
    I just spent about an hour on that site lol.... Found some cable routing stuff I hope I can make work... provided I can buy in smaller quantities than 100 packs of 100 each lol...
    Couldn't locate any RCA covers, but thats fine.
    I guess I'm just not sure if I need the noiseblockers for JUST the RCA inputs, or also the video ones I'm not using (Composite/Component)....
  • voltz
    voltz Posts: 5,384
    I highly recommend the ones from Vincent, their german you know ;)
    all I see are the XLR caps though, I must have bought all the RCA ones, my bad!
    voltz wrote: »
    LOL... yeah XLR wont work well for me hehehe..... I will see what I can find there though, thanks!
    Dan,
    Search this on eBay
    "12 noise stopper RCA cover"
    You should get 24 listings one is 20 for 17 bucks many come up including rhodium plated
  • afterburnt
    afterburnt Posts: 7,892
    Holy carp now I need a couple of hundred of these?
    F1nut Posts: 51,893
    Go to Audiogon, look for apolloav. Nice RCA caps, 50 for $54.95.
    Thanks @F1nut !
    Those look like just the ticket, and it covers all the outlets with some extra left over for my integrated upstairs!
    Now to see if there is something similar for HDMI ports, or just buy those cheap plugs to cover the outlets.
    F1nut Posts: 51,893
    B)
    B)
    Now to get some better cable management pieces so the back of my rack looks nice and clean....
    Ended up buying the Apollo-AV ones suggested by Jesse @F1nut . 58 bucks for 50 EMI/RF covers works great. I really only need 42 to cover everything, which leaves me some upstairs for my integrated as well.
