Armacell & Rdo194
[Deleted User]
[Deleted User] Posts: 0
edited March 2016 in Speakers
Has anybody ever put that Armacell tape on the back of some tweets as a replacement gasket? Good idea? Bad idea?
  • motorhead43026
    motorhead43026 Posts: 4,131
    Yep, works well.
    And the boots you lick will stomp you too.
  • amb426amb1
    amb426amb1 Posts: 148
    Some refer to sheets of armacell? Is there a narrow tape available as well and I'm having a hard time finding retail outlets for the stuff.
  • motorhead43026
    Armacell is sold on rolls. I found mine @ Home Depot.
    It is 2" wide
  • amb426amb1
    Ok thanks will look at home improvement centers for this brand.
  • leftwinger57
    leftwinger57 Posts: 2,917
    Yep, I also got mine at Home Depot. I think it was $8 for the roll. You'll have to take a sharp blade to it and make it to size. My tool prep for my mods on the 2Bs. tiziqq4epxpc.jpg
  • 11tsteve
    11tsteve Posts: 1,166
    it can also be had on Amazon... if you don't like leaving your house and aren't in a hurry...
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
    F1nut Posts: 52,406
    Of course, you could simply leave your stock gaskets alone if they are not damaged. After all, they were specifically made for the job unlike the window gasket.
  • [Deleted User]
    Unfortunately the original gaskets have definitely seen better days. But I'm pleased with the results of the Armacell on them.
