Speaker replacement advice
I am hoping I can get some advice. I currently have a Home Theatre set up with PolkAudio speakers as follows.
AV Receiver - Onkyo TX NR609
3 VM10's - Front - Left, Right, Center
2 FXi30’s - Rear Surrounds - L & R
1 Cambridge Soundworks - Cube8s Subwoofer
The FXi’s are too big and I am looking to replace them or swap out the front 3 and move the VM 10’s to the rear spot.
If I swap out the front three, I would want to replace them with something similar in size or smaller. Definitely not bigger.
I also, don’t want to give up sound quality.
Do you have any suggestions on speakers that will work for me?
This is what the room is like, not ideal but its what i have to work with...
Shawn
___________
Onkyo TX-NR609 (receiver)
Sony Blue ray Player
Sony 46" LCD TV
Comcast HDTV X1
VM10 (Center)
VM10 (Front Mains)
FXi30 (surrounds)
Cambridge Soundworks Cube8 (sub)
    tonyb Posts: 33,072
    Hmm....the FX's are too big ? Seem perfect for that sized room. In any event, look at the Polk TL series.
  • Well, I think they are fine, but my wife feels they are too big. Asthetically, they don't fit well. If I had a seperate room, it would be one thing, but such is the battle... I still have my RTi38s and CSi centers tucked away in a closet. They were also deemed 'too big'
    Shawn
    Shawn
    ___________
    Sony 46" LCD TV
    Comcast HDTV X1
    VM10 (Center)
    VM10 (Front Mains)
    FXi30 (surrounds)
  • After more reading, I am leaning toward the TL3 series. Although, PSB Mini's look interesting, although they are much more expensive and I am not quite sure I want to spend that much
    Shawn
    ___________
    Sony 46" LCD TV
    Comcast HDTV X1
    VM10 (Center)
    VM10 (Front Mains)
    FXi30 (surrounds)
