In-ceiling surrounds to match SDA fronts
Hi, I have some vintage Polk speakers (SDA 2B) for my mains, and I'm now looking to add speakers for a theater setup. From Polk's current line, it has been suggested that I go with a CSi A6 for the center speaker (or a CS400 if I want to get something used). I'm now seeking advice for the surrounds. Because of my room, I will need to go with in-ceiling speakers. Is there anything in Polk's current line that would be a good match with the SDAs that I currently have?
Thank you,
Greg
  • rooftop59
    rooftop59 Posts: 8,120
    edited February 2016
    I would go with a cs400 (or 400i) for the center, not the csi a6. As for surrounds, I personally do not think that matching matters as much unless your playing a lot of high-def surround channel music (blu ray concerts, sacds and DVD-As). So I think anything from polks current lineup would be pretty solid. If you really want to match, you will have to try to find used or NOS surrounds that match the cs400i. You might have to ask customer service what those are...
    Game Room 5.1.4:
    Bedroom 2.1
  • michael1947
    I used an A6 with my SDA=SRS and it was great and I had tried 3 others.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • Gunther16
    I'm using the vintage FX1000 which seem to be a perfect match in timbre. Never looked back! Of course they are on the wall not in ceiling speakers.
