WTB mutli-channel amp, 3 or 5 channels
3 OR 5 channel amp wanted. Parasound or Adcom preferred. Needs to have a 12v trigger if possible and plenty of power in case I get bigger speakers. Looking to spend $600 through paypal.
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
  • quickr1
    quickr1 Posts: 414
    I know you said preferred but there is a emotiva 3 channel amp in the classifieds. Also a rotel 5 channel in there. Both are nice amps.
  • Nightfall
    Nightfall Posts: 10,083
    edited February 2016
    This is a little more but what a nice amp for the money. 5 channel, 200 watts @ 8 ohm, 375 watts @ 4 ohm, balanced and unbalanced connections, 74 pounds, designed and made in the USA. I want to say @EndersShadow has this amp? I'm not feeling totally confident on that one, I know one of our regular posters has this amp though. Maybe they will stumble on this thread and tell you about it.
    http://www.ebay.com/itm/B-K-Reference-200-5-5-Channel-Power-Amplifier-/252285671853?hash=item3abd65d9ad:g:zRYAAOSwx-9Wu1u9
    If you really must stay in your budget this one has a little bit weaker of a power supply and "only" 3 channel. 220 @ 8 ohm, 325 @ 4 ohm
    http://www.ebay.com/itm/B-K-Components-Reference-3220-Power-Amplifier-325-watts-channel-into-4-ohms-amp-/151986671448?hash=item23631c8f58:g:RWkAAOSw~OVWxJXd
    afterburnt wrote: »
    Village Idiot of Club Polk
  • scubalab
    scubalab Posts: 3,105
    Hey Nightfall, that is the same amp Enders has. He and I have been talking a bit lately as I'm about to buy a B&K Reference 200.7, and he's given me a lot of tips and advice. I think that amp would work great for Mr. Sharpe.
    I will throw in my shameless plug for my Rotel for sale... It would fit the bill perfectly (5 channel, 12v trigger, 200 WPC/4 ohm), but it may lack the overall power you're looking for to future-proof it. Although, at my Polkie price (PM me if interested), you'd have plenty of that budget left over for some nice ICs. :) It's plenty for me, works perfectly, and the only reason I'm upgrading is for the extra two channels in the 200.7. Completely understand if you're looking for something with more power and wouldn't want to push something on you that isn't exactly what you're looking for. If that's the case, the B&K 200.5 looks like a better choice, and you could probably find one cheaper than that ebay listing.
    Here's my FS ad:
    http://forum.polkaudio.com/discussion/171740/rotel-rmb-1075#latest
  • scubalab
    Also want to add that I have had B&K, Rotel, Carver, and Parasound amps. I will say that the Parasound, B&K, and Rotel all have a similar sound (to me anyway!) - somewhat neutral to a little warm. The Carver is a little bright, but not overly so. I haven't heard Adcom yet, but I can say that Parasound is a great choice.
    -Al
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    Well is B&K worth a try??
    Yes I need future proof that's why I mention Adcom because they've got some big ones. someone has one and a processor for $750 which is a little high because I don't know what I could get for the processor as I don't need it.
    I just like a parasound because it would look cool sitting next to my 1500a:) ya know, 1205 1203 etc.
    maybe even two mid sized stereo amps, one bridged for the center and other used for two channels. I lean to parasound because they are nice quality amps, with so many features lol
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • scubalab
    Couldn't agree more on the Parasound, and wanting your equipment to 'match'! A 1205 would be ideal. The Rotel is definitely a statement piece (as far as looks go) with that heat sync look on the front! Might not appeal to some.
    If by chance you got any questions on the Rotel just let me know, but I think you're going in the right direction with a multi-channel Parasound!
  • madmax
    madmax Posts: 12,434
    A co-worker has the B&K 200.5 and is very impressed with it.
    Vinyl, the final frontier...
  • slbenz
    slbenz Posts: 97
    I owned a Parasound HCA-1205A for almost ten years. It was a nice sounding multi-channel amp with enough power for my Magnepan IIIas. Just make sure if you do buy one, to give plenty of ventilation above the amp. It can generate quite a bit of heat.
  • Nightfall
    Mr. Sharpe wrote: »
    Well is B&K worth a try??l
    Absolutely. Both (Parasound) are good for the money though.
    afterburnt wrote: »
  • Mr. Sharpe
    Hca-1205was on ebay and I snagged it! Right at my budget too:)
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
