setting VTA w/ Shure "Audio Obstacle Course"
Have a Shure (vintage) vinyl "audio Obstacle Course" # TTR 110, for checking testing and setting up trackability. Anyone use or have an opinion on usefulness or accuracy in setting VTA and A/S on my denon DL110 using this as a template??????
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
  • soundfreak1
    soundfreak1 Posts: 3,414
    Wow, no one heard of these?
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • jdjohn
    jdjohn Posts: 3,388
    Although I don't have one of those, I have read in other forums about them or similar records. If you really want an opinion on this, you could post over at VinylEngine.
    Having said that, what I have read indicates that these types of records can be EXTREMELY finicky in that you may never get it to sound perfect no matter how good your alignment, VTF, or anti-skate is. It's almost an unwinnable game. Of course it's not a 'template' per se, but more of a tool for listening to see how close your settings are, or to try different settings and listen to the difference.
    I'm assuming you've already used a protractor of some type for alignment, and have a proper scale for setting VTF? That Denon should be a very nice-sounding cart.
  • soundfreak1
    Yes the 110 is very nice. A protractor was used.just finished rebuilding the SL 1700 so what's next? LOL
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    BTW Your take on the record is spot on imho, a tool and referance point maybe.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
