Matching tubes
mikeyb128
in Electronics
I've been on the hunt for RCA 5814A black plates, I see a lot on eBay, but I'm having trouble finding a quad set. Is it ok to mix up year? Say a 1965 with 1964? And do they all need to be closely matched? Thanks everyone.
2 channel:
Theater:
Theater:
Best Answer
Yea I think you're right preamp tubes don't get bias.
I try to match type and getter, plate size and color, number of mica, but i havent worried about years unless we're talking 80s/90s to 60s. I'm relatively a noob too tho, been learning what I can for the last year. I think those Gold Lions are easy to find because they are either 1. expensive original ones or 2. less expensive russian/chinese made not original ones. Definitely not an expert here, you need the services of some of some senior Polkies.
H9 is your man - several others as well but he seems to have it all plugged in.
in the mean time - here's what I gots for ya.
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Answers
I can only answer with a question - is your amp self biasing? The close matching isn't as critical if it's self biasing like my Dodd as I understand it.
That's the limit of my contribution though - sorry. I may have a 5814a BP laying around though - I'll have a look and let you know.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
They will be used as pre amp tubes. I'm new to tubes, the stock ones in my Cary sound very nice, but the reviews state there is a helluva lot of potential in the pre amp with a tube roll.
From what I read pre amp tubes do not need to be re-biased.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Carys website recommends Genelex gold lions as a premium tube upgrade. Which are easy to find. I hear good things about the RCA's.2 channel:
Theater:
The new gold Lions are made in Russia, I have some NOS Russian tubes in my shanling and I really like them. I read good reviews for the gold lions.
That definitely is a balck plate RCA. I see some NOS on eBay for about 30-40 bucks a matched pair. Might scoop some up. I know vintage tubes usually prevail, just worried about reliability.2 channel:
Theater:
I've had pretty good luck honestly if you're careful with feedback on the 'Bay.
That one tests fine, happy to send it to you just PM me.
Yes, I have some Treasure 6Ca7's that are Chinese that Jesse recommended, top quality and fantastic tubes, best I have tried in the Dodd. Didn't mean to denigrate the makers of them, just make the differentiation between the two.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Thank you @MrBuhl ! Sorry for the late response. I tried to pm you regarding the RCA tube, but I can't for the life of me get pm to work, which worked fine before. I did however find a matching quad of RCA 5814A 1965 black plates for around 70 bucks shipped to my door, they test strong and are in great shape besides worn off silkscreen.2 channel:
Theater:
It's less about this brand is better than that brand and more about what sound you like, as long as you're not talking about $10 Chinese tubes. That is my take on signal tubes so far.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Nightfall, trying to find that sound, and doing it with a reasonable budget. The original question was matching years for vintage tubes as it seems hard to find quad sets for a reasonable amount.2 channel:
Theater:
