I'm new and need help
kevinapple
kevinapple Posts: 6
edited February 2016 in Electronics
I have the Polk audio RTi a7, CSi a6, FXi a6
What would be the best Reciever and Amp for these speakers
Movies/music is 60/40-ish
Room size 14w/11h/20L
No windows just 1 door at the rear of the room
Sitting around 10 to 15 feet away from screen
Also what sub setup would be better: 1 sub PB-13 ultra or 2 subs PB-12 Plus
Budget is around $7000-ish
  • ken brydson
    ken brydson Posts: 9,058
    Budget $7000 or did you add a zero?
  • I could spend up to $7000 if needed. For 2 subs a AVR and a AMP....I'm new to building a home theater. So maybe I over saved...lol
  • afterburnt
    afterburnt Posts: 7,892
    Parasound Halo A51 Five Channel Amplifier
    PB13-Ultra
    There I spent all of that pesky money for you.
    PS: Contact "Dskip" here for the amp
    OK if you really need an AVR you can get an A31 and then you will have money for a Yamaha RX-A ****
    txcoastal1 Posts: 13,519
    AVR: Marantz AV7702mkII Atmos ready and DTS-X upgrade-able when released
    AMP: Sunfire Theater Grand Amplifier - TGA-7201
    PM @DSkip he can work you up a quote
    and 2 subs PB-12 Plus
    I have demo'd the Marantz and own the 7201...they will be my next HT combo
  • Thanks for the help!!!
    F1nut Posts: 52,146
    I like the Pioneer Elite AVR's for a few reasons, one being I think their calibration program is the best.
    As mentioned, one of the Parasound Halo amps would be a good choice.
  • With that budget, I would look into a standalone preamp/processor such as the Yamaha CX-A5100 then add a multi channel amp for the center and surrounds, and a stereo amp for the mains. Any of the amps listed above would do great.
  • chumlie
    chumlie Posts: 8,658
    I'll second that.
  • Don't forget about heat, wiring, room treatments, clean power, interconnects...
    if you go top shelf ... I haven't built a home theater room. Sounds like fun!
  • BTW, is that your boxer?
  • chumlie
    This should do the trick until you can get an amp to go with it. Looks like an open box deal on Amazon for $700. And it has the pre-outs you need for an amp,
    http://www.amazon.com/gp/offer-listing/B00LIQ3HXC/ref=dp_olp_used?ie=UTF8&condition=used
  • I like 11.2 myself :)
    Maybe someone who has dabble w/ Atmos can chime in.
    I picked up a Denon AVR-4520ci for not much more bones
    because I new Atmos would never be in the picture.
    Two subs are better than one but if you haven't put nice power
    to those fronts yet I'd just get one and see where you are at.
    Thanks for the help. Yes that is my boxer female named Ginger
  • Thanks everyone for the help and guidance. Much appreciated
