New guy with a question
Systems
Hey guys, i'm in the middle of building a 03 Vibe GT. I have the MM6 componets for the front, and just purchased the <2>MM2124
12's yesterday. I was curious if the Polk/MOMO carbon series C300.2 would be able to power both of these??? I don't have alot of experience with subs. Always used a 8 or 10 to complete a system, but they were mostly designed for clarity. I wanna hit, but keep my clarity. Would it be a better idea to only use <1> 12????? Thanks in advance for any responses.
Testing
Testing
Testing
Testing
Testing
I love polk...but a 500.1 will not power 2 2124s
they are rated at 400 watts...youll be giving them 250 each...
you can run a 2124 off of one 300.2 though...but keep the gain down
or you could get 2 300.2s, one for each sub
-Cody -
I just recommended this Coustic in another post. It puts out an underrated 400 rms x1 or 800 at 2 ohms. Its perfect for your subs and is only $280. Coustic is a very good amp and built very well. Theyre owned by Mitek which owns MTX and Xtant so you know youre in good company.polkaudio sound quality competitor since 2005
I definitely agree that these are some fine amps, my only complaint is the high price.
Take the Polk 4 channel, its $500. For that you can get a high end competition level amp like an Xtant, PPI, Orion or JL Audio. I just dont consider Polk to be in this league.
However Car Audio and Electronics just reviewed the 300.2 in this months edition and gave it very high marks so what the hell do I know?!polkaudio sound quality competitor since 2005
nice amps, need to make em bigger
537 watts at 14.4 volts is barely over 500 watts
cars usually dont run at 14.4v, you have things like a/c amongst other things to cosider
in reality its closer to 12.5-13volts
i have a 2001 model RF amp thats the same as the polk c300.2
its rated at 13.9 volts and puts out 810 watts of power, a 500 watt amp that puts out 810 watts of power
THATS underrated
and all but one of those reviews say exactly what i said in my previous posts, good amps, not enough power/doesnt match up with polk's subs
-Cody -
Well, i ended up taking one back. So the C300.2 would be good for the one 12????? Thanks for all the input.
the sub is rated at 400
the amp is rated at 550
just keep the gains down and youll be fine
-Cody -
Thanks for the help, i just bought the C300.2, so as soon as i get my box and everything installed i'll throw up some pics
250 - 260 to a mm2124 is do-able... it is, as cody states, underpowering the sub, but it will still sound good. it'll do the job, but will not be as loud as if you had more power. case in point... i've got about 230-ish on some DX10's in the ex-girlfriend's car... they sound fine... but they don't sound as good as they did with about 400-ish each on them off the 8100d @ 4 ohms.The Artist formerly known as PoweredByDodge
