surrounds for csi3 and rti4
powers20
powers20 Posts: 21
edited May 2008 in Speakers
i just got the csi3 and rti4's and they sound great, but i can't afford to get more rti4's or the fxi's either. What cheaper, perhaps older polk speakers would work good. I've got 4 speakers to replace. the side and back pairs. Or should I try a different brand? Everything i have read says to stick with speakers of the same "family". Does that mean same brand or same drivers and tweeter material?
Front RTI4s
Center CSI3
Velodyne ULD-18 Sub
Pioneer DV-563A Dvd, SACD, DVD audio player
Sony CDP-CX355 300 disc CD player
Technics SL-7 turntable
Yamaha RX-V1400 A/V Reciever
Dish Network DVR
Playstation 2 and 3 both optical out
Sony Wega 34" Widescreen CRT HDTV
Post edited by powers20 on
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited March 2004
    Same brand and tweeters is the simplest.
  • fgr41
    fgr41 Posts: 432
    edited March 2004
    Keep your eyes open here and on ebay. You may be able to find some good prices if you are patient.
    For Home Theater it's best if you are able to have all the speakers timber match. By timber match I mean all have the same tweeter and woofer so the sound quality is very similar. It helps with making the sound in the room seem seemless.
    Front
    Polk RT800i (BI-wired)
    Rear
    Polk RT600i
    Center
    Polk CS400i (BI-wired)
    Sub
    SVS 25-31PCi (22Hz tuning port)... it's SubHuman
    Receiver
    YAMAHA RX-V1400
    TV
    Mitsubishi WT-46807 HDTV
    HD receiver
    T i V o HR10-250
  • Donduck
    Donduck Posts: 7
    edited March 2004
    I just hooked up my new Yamaha rxv1400 with PLIIx.
    I have the RTi4's for front and the CSi3 for center.
    I have 4 Polk R15's for my side and rear surrounds.
    People say they are not timbre matched but I don't believe that.
    I used the AB switch to jump between the RTi4's and a pair of R15's. Every thing sounds exactly the same except the RTi4's have a hair more volume.
    I got my R15's for $38 apiece (retail $89 each) at our local AmericanTV store in Wisconsin. Can't get them on their online store.
    For 2-channel music Dolby PLIIx is superb with this set up.
    Only had a little time to check some movies out with my speaker setup, but what I haved checked out it is truly awesome.
    By the way, the Polk PSW303 subwoofer is performing fantastic also. Don't know why that gets some bad reviews.
    I manually setup everything with the sound and vision disc and my radio shack dpl meter. Don't know if I will use Yamaha Auto setup feature.
  • Willow
    Willow Posts: 11,228
    edited March 2004
    I would go with the R15 as well , they are innexpensive but decent speakers. If you are stuck, you don't need to have the rears timbre matched,it's suggested they are but not mandatory, the rears don't carry the majority of the sounds or effects. If you're on a budget and want polks go with the r15s
  • powers20
    powers20 Posts: 21
    edited May 2008
    Thanks alot for the input guys. Are the Monitor 30s a better speaker than the R15? I looked at them in CC, and they look almost identical to my RTI4. Same exact tweeter. The same size woofer also. I liked the mounting bracket on the Monitor 30, although they are pretty deep for wall mounting still. Anyone have a picture of the back of the R15. I wonder why this site doesn't show the back view of the speakers. Any help would be great. I'm still not ruling out fxi for side either. I think I will definately have to get Atrium 45 for rear surrounds(7.1) because of room limitations and I want to use existing mounting hardware. Would the Atriums sound too different to blend with this family of speakers?
    Front RTI4s
    Center CSI3
    Velodyne ULD-18 Sub
    Dish Network DVR
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2008
    This thread is 4 years old
  • powers20
    powers20 Posts: 21
    edited May 2008
    oops I see that now
    Front RTI4s
    Center CSI3
    Velodyne ULD-18 Sub
    Dish Network DVR
  • dylanblada
    dylanblada Posts: 77
    edited May 2008
    welcome to 2008
  • devani
    devani Posts: 1,497
    edited May 2008
    so 4 years later, how are the speakers?
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • powers20
    powers20 Posts: 21
    edited May 2008
    It doesn't seem that long ago. They're still 100%. Love em. But I do agree with some other people who posted about the CSI3 not being shielded enough. I have a CRT with a stand on top for the CSI, and I notice a little distortion on my screen. I'll have to rig something. What about dynomat? Does that stuff have any magnetic shielding properties? Anyway, I'm still in the same spot I was 4 years ago, trying to complete my starter HT. I think I've decided to bite the bullet and get the FXI3 or A1. More money than I wanted to spend, but oh well. Cry once, and be happy for a long time. I still gotta find something small for my back surrounds. Theres barely any room, so the Atrium 45 is what I'm looking at. Even if it's not perfect, It will be a huge step up from my RCA 50wpc two way swivel bose wannabees. They suck.
    Front RTI4s
    Center CSI3
    Velodyne ULD-18 Sub
    Dish Network DVR
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited May 2008
    What'd you end up getting for your rears? I feel so behind the times, I just got my RTI6s, and looking for RTi4s.
  • powers20
    powers20 Posts: 21
    edited May 2008
    I went ahead and got the FXIa6 from crutchfield, and got the free Atrium 45s for my back surround. I know they are probably not the perfect match, but they will be better than what I got now. Actually Crutchfield's description of the Atriums says they are voice matched with the RTI series, but I think they are wrong, being that the tweeters are totally different. But I still don't understand that stuff. In a perfect world, I would have gotten the RTI6 for fronts and moved the RTI 4 to rear back. Maybe in my next house. The Atrium deal ends today if your interested. Got to spend 500 bucks to get it though. Good luck, and thanks to everybody for their input.
    Front RTI4s
    Center CSI3
    Velodyne ULD-18 Sub
    Dish Network DVR
