Anyone familiar with TriangleArt turntables?
Going to look at one in a few days and very tempted to pull the trigger. Even have the wife's blessings on it, just don't know much about the except they are beautiful and expensive. I would still need to find an arm for this one as well.
  • chumlie
    chumlie Posts: 8,658
    They sure look pretty. Just my opinion. Doubt you will get much feedback. Lovely wife you have.
    txcoastal1 Posts: 13,519
    I know I have looked at them a time or two. Seen a couple at shows, but I'm not a TT aficionado. Really like the looks of the Symphony SE. Lotta' weight 200lbs, even the Symphony @ 120lbs is a beast.
    I'm assuming you are going directly to TraingleArt since they are based in Cali???
    Good luck chief...they are a bute'
    nooshinjohn Posts: 26,064
    If you are in the market that's a lot of table for the dollar, I personally wouldn't hesitate, you know when you have that feeling
    You are definitely walking into Class A territory
    A graham or a SME V would be my thoughts as a tone arm to build around
    I know you have the patience to build around a system
    Cheers
    Thanks... my thought would be to polish the crap out of it and paint a couple pieces to match my amps, then set it on a matching black granite base.
    Excellent idea, I was even thinking a little pin striping to jazz it up
    msg Posts: 10,536
    maaan, that's beautiful.
    after reading up on it in that link, I'm thinking you might want to bring a mechanic along?
  • erniejade
    erniejade Posts: 6,321
    That is a work of art and beautiful. Nice choice.
  • xsmi
    xsmi Posts: 1,804
    I've heard one and I honestly wanted to leave with it but definitely didn't have the coin. Right now, its the table in my lottery system.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Man...that's the kinda stuff that wakes up in the middle of the night in a cold sweat, hope you can call it yours one day!
    xsmi wrote: »
    It's definitely an end-game piece, and at that price, hard to pass up given what the production version sells for.
    Looks like game over for my turntable quest...
  • xsmi
    xsmi Posts: 1,804
    Congratulations! Let us know what it's like after you've been with her for awhile.
    xsmi wrote: »
    You are jumping to conclusions my friend... over could mean someone else grabbed it. :'(
  • xsmi
    xsmi Posts: 1,804
    NNNNOOOOOOOOOO!!!!!!
