New (old) Amps, reconfigure 2ch system.
Well I got bored with my setup, so I took it all apart.
I removed my Crestron Amp, Crestron Processor, Sonos, Network Switch, B&K Ref30, Pioneer BD(CD) Player.
Reinstall the Squeeze Box, Xbox1 (cd player via optical to squeezbox), B&K Ref5s2, kept the turntable, installed the MusicstreamerII USB DAC.
I replaced the Crestron (ATI) amp with TWO Rotel RB-1070s. I played with the bridging option for a bit and decided I don't like the way it sounds. The RB-1070 in bridge mode outputs 330-360w @ 8 Ohms. I Think it was too much for the tweeter and mid b/c it juts sounded the way everyone who doesn't own B&W speakers describes B&W speakers ( harsh highs).
I separated the amps up into left speaker and right speaker.
The B&K stereo pre has an awesome combo of outputs. They give you full range out, high pass out, low pass mono L+R out. So I'm using the high pass and low pass out to each amp channel.
I also reduced the size of my speaker cables too, just for a cleaner look.
Speaker cable and spade connectors are by IXOS.
Reused all my MIT interconnect cables.
I had some great, heavily insulated, overkill power cords I used on the amps.
Left some spare sources on the empty shelf for when I want to tinker ( like a USB DAC source, optical, coax digital, and some power cords) ( the wires under the turntable).
So far I am happy with the sound ( insert some rant with overly descriptive words here about how good it is) and new look of the whole rig. Old Rotel amps are great.
Here are some pictures:Click to Enlarge
Ignore that missing wall plate... I know, I have it.
B&W CM9Classé Sigma
