what to use for my rears
Hey I need some help. I am upgrading my HT I just got the 705's 706 and own the lsi9's but need help on the rear surounds and sub. for the rears should i use the 702's or 703's 60/40 music and for the subs would two 660's be to much. room size 22x24
thanks for your help
  • gce
    gce Posts: 2,158
    If your 60% 5 channel music I'd go with the 703's and for a sub you'll enjoy another brand like a SVS. What are you powering all this with?
    Anaheim Hills CA,
    HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
  • jghglofer
    jghglofer Posts: 100
    gce : onkyo tx-nr3010, adcom 565, parasound 2250 and wanting to go 7.2... this is all new stuff for me hope it all sounds good when done.
  • Polkie2009
    Polkie2009 Posts: 3,834
    Since you already own the LSi9's (right?) , I'd try them as back surround speakers. Really there's not a huge__ amount of signal going to the back surrounds. Depending on what your budget is for the bass duty, I'd definitely recommend getting 2 subs for your size of room. Plus acoustic treatments and sub eq. if your onkyo avr doesn't provide that.
  • erniejade
    erniejade Posts: 6,327
    Agree with 2 subs. Lots of good sub brands out there and lots of choices and agree not going Polk for the subs. What's the budget?
  • jghglofer
    erniejade: 1200 on the sub buget hopefully less. polkie2009: was was wanting to step up to 7.2 on the surround thats whyni was asking about the 702 or 703 but for music i th=ink the 703's would do a better job but just wanted to hear from somebody that has had them
