Sub Level on Deck
swerve
I have an Alpine CDE-7870 head unit and i have the sub level vol. turned up to 5... it goes to 15.. I'm running a C500.1 amp and 2x MM2124's, should i leave this where it's at?
thanks
adam
thanks
adam
cats.vans.bag...
Post edited by swerve on
if the gain on the amp's been properly set, i would be careful turning up the sub's output level from the hu. id turn other things down instead. it's all about balance. and not cooking your equipment.It's not good, very fundamentally simply not good. - geolemon
I think it's balanced pretty well, ill leave it how it is.cats.vans.bag...
actaully..by having it at 5..you have it set quite low- as according to alpine... 15 is nominal use... then you taper off... at least with my 7908...
