Pioneer Elite SC-67 vs Denon AVR-X4100W
dpowell
dpowell Posts: 3,081
edited January 2016 in Electronics
I currently have a Pioneer Elite SC-67 in my home theater. I have an opportunity to switch to a Denon AVR-X4100W for a very good price if it makes sense. A couple of things stand out on the Denon that the Pioneer doesn't offer at this point:
Audyssey Multeq 32 and DSX LFC (which would be beneficial for the dual subs I run)
Dolby Atmos support
The Pioneer has a higher MSRP than the Denon and I have read that there may be a preference one way or the other with respect to the sound reproduction between the two. That said, I have a Pass Labs X1 that I use in HT bypass for music and I use a Sunfire power amp for the front mains and center. I only use the internal amp on the receiver for surrounds.
Thoughts?
  • DollarDave
    DollarDave Posts: 2,575
    I own the Denon 4100w and a Pioneer SC-87 and a Pioneer SC-82. Hands down the Pioneers sound better, have more reserve, and their auto calibration is more accurate.
  • dpowell
    Great, thanks for the input!
  • polrbehr
    polrbehr Posts: 2,857
    If reserve power is not really that important, and you plan on using Atmos, it may be
    worth a try going with the Denon.
    I happen to like Denon, but I would probably stick with the Pioneer anyway, unless the price of the 4100 is insane and you could resell it tomorrow if need be?
