Question on Marsh Sound Design vs Channel Islands Audio Amps
slbenz
in Electronics
Doing a search and I notice several forum members having experience with a Marsh Sound Design A-200s. I am looking at that stereo amp and a set of Channel Islands Audio D-200 monoblocks. CIA's first generation of this monoblock. Have any of you compared the two? I am looking to power a set of Polk SDA 2Bs that I have. Thanks in advance.
Haven't heard either, but I think Doug had the Marsh at one point, or still does. I believe he really dug it too.
Pretty expensive amps for 2b's though in my opinion.HT SYSTEM-
lsi 9's -
Since I am still a bit new to this forum, what is Doug's moniker so that I can PM him? Also these amps on the used market aren't bad on price vs. when they were new. Thanks. -
DKG I believe....don't know if he chimes in much these days though.HT SYSTEM-
lsi 9's -
@dkg999 , he pops in once in awhile... -
Thanks to the both of you. I will PM him for his take on the Marsh amp.
A long time ago, I thought h9 heard a marsh and said it was really good
Did Doug get back to you? I can message him of FB... -
ken brydson wrote: »
Haven't heard from him as of yet. -
Thanks for your help. Will let you know when I hear from him. -
I don't have experience with the amps you listed, but I did own (and love) a set of 2B. If you went with the Channel Islands monoblocks, you'll need to use an AI-1 interface instead of the regular SDA interconnect.Wristwatch--->Crisco
Thanks. That is good to know. I asked that question on the Channel Islands forum and am waiting for their response on this. -
Just received an answer from the owner of Channel Islands Audio. The owner doesn't think there should be a problem but it doesn't matter now. I just took ownership of a Marsh Sound Design A200s I found locally. Now that I had a chance to listen to the amp in my system, I can understand all the accolades for this amp. It creates a very wide sound stage with rich mids with very clear highs. It makes my modded 2Bs the equal, if not better than my Magnepan IIIa mids using a Wyred4Sound ST-250 amp. The bass out of the Marsh amp is very well controlled and even better than the Rotel RMB-1565 in my home theater set up which has a similar output but the Marsh sounds more dynamic and authoritative.
To those of you that helped me to reach out to Doug, he just answered my request for information this morning. He supported the experiences that I am having with the Marsh amp with my SDAs. Thanks to all that helped me with this amp decision. Still good to know that if I decide on a Channel Islands Audio amp, the only one the owner said that wouldn't work with SDA speakers is his bridge D-500MKII amp.
Glad you like the Marsh amp, and sorry for taking so long to answer your message! I need to make an effort to stop by CP more often.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Slacker...
