Wireless security camera system
gwh
gwh Posts: 1,451
I have been thinking about getting a wireless camera security system for the compound and it looks like there is a ton of stuff out there with different options. I would like at least six cameras(option to add more) with night vision capability and a dvr. I just don't want to go out and buy something and have regrets later. If your an expert or have experience please share your thoughts. As always I appreciate the input here.
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
  • ken brydson
    ken brydson Posts: 9,047
    No personal experience but Costco has a couple systems and a very liberal return policy.
    pitdogg2 Posts: 27,488
    edited January 2016
    I'll be watching this also. Been thinking same thing. Seen several at Parts express but most are out of price range or just do not match my needs. Most I seen with night vision are very limited range or very fuzzy resolution. I also have no computer and aluminum siding that will play havoc with the wireless cameras...or so I hear
    Get a dog, they have decent night vision too. Better than mine at least.....and they are wireless.
    EndersShadow Posts: 17,732
  • Zmodo has decent system for the budget minded. I have a 4 camera system 3 outdoor 1 inside complete wireless setup no DVR, didn't feel the need to record/store everytime the motion sensors went off. I get alerts on my cell phone and I can control if I want to record or just take a snapshot.
  • RamZet
    RamZet Posts: 792
    Check out Ring. They have a wireless cam now too. Two way audio, cloud storage, easy setup.
    Drop cam is good but more than three can cripple your average network.
    If you have the money, look at icrealtime.
    B&W CM9Classé Sigma
    txcoastal1 Posts: 13,519
    The problem with wireless is it really wireless, not really as most still require power. Will you be able to get power to the locations?
  • WagnerRC
    WagnerRC Posts: 2,217
    I use dropcam and it works great
  • tonyb wrote: »
    LOL, good one Tony!
    I'll be watching this thread. Very interested in getting a system too.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
    tonyb wrote: »
    Except easily corrupted...... Lost a nice audio system 25 yrs ago due to a large chunk of beef...
  • RamZet
    RamZet Posts: 792
    edited January 2016
    Ring doorbell.
    Has a camera, two way audio, easy setup, cool app, and can be wired or you can use the battery that is built in ( last 1 year).
    http://www.amazon.com/Ring-Wi-Fi-Enabled-Video-Doorbell/dp/B00N2ZDXW2/ref=sr_1_1?s=hi&ie=UTF8&qid=1453782165&sr=1-1&keywords=ring+doorbell
    https://ring.com/how-it-works
    Ring Camera, same deal. Has a battery built in, works on WiFi.
    I have the Doorbell and its great.
    https://ring.com/stickupcam
    another cool thing they offer is stolen cam/doorbell replacement. So if somebody takes you gear, they will send you new stuff.
    B&W CM9Classé Sigma
  • The next one I will be getting in March
    Zmodo Smart Door Light and Connected Doorbell
