Polk Rc65i vs VS-625 RT vs SC65i
Emailed Polk for an answer on this one, got no reply. Maybe someone here can help. Need some in wall speakers for surround duty. All the above can be had for about $200 a pair Canadian. Which ones are best?
  • polrbehr
    polrbehr Posts: 2,853
    They all look to have the same specs as far as driver complement.
    I happen to own a pair of RC65i (used as surrounds as you're planning to do), and have nothing but positive things to say about them. They install easily, and have 6 brackets to hold them firmly in place. I also like these over the other 2 you listed because the RC65i has a swivel-mounted tweeter, and as such would likely be better for surround duty.
  • Spec wise you're right, they're all about the same. I tried basing it on regular price, for example the VS-625 are "regular" price $400 per pair, but the Polk site lists them as a "budget" in wall. Very confusing.
