Woot! Scored a pair of Sanus Ultimate Foundations
Seller didn't know what kind of stands they were, so they didn't show up in a search. Not a giveaway price, but more than fair considering what else is out there for the same money. 26" tall ones. My recently acquired LSI7's will be getting a new perch.
    tonyb Posts: 33,065
    Cool man, what was the old perch ?
  • tophatjohnny
    tophatjohnny Posts: 4,185
    I had a set of those with SDA CRS +'s and they are amazing. The spikes are like weapons.
  • DaveHo
    DaveHo Posts: 3,581
    Was using a cheap pair of MDF stands that were part of a package deal with other speakers I had bought long ago. Too tall and could probably be blown over with a strong wind. Now I'm trying to decide what to fill them with. Sand, shot or a combination of the two. I think if I fill them with only shot, I'll probably end up spending more for the shot than the stands. Any recommendations for an inexpensive local source? I have a Cabelas not far from me, but that's probably not going to be inexpensive.
  • rooftop59
    rooftop59 Posts: 8,121
    the sand i buy at Lowe's for my kids sandbox has lots of peddles in it and its pretty dense. I would be inclined to try that first and see howe you like it. I've done sand in quality steel stands in the past and it was SOLID!
    Game Room 5.1.4:
    Bedroom 2.1
    F1nut Posts: 51,674
    It would take an incredible amount of shot to fill the columns. I used a mix of shot and sand. 25lbs. of shot per stand, divided between the 3 coulmns plus the sand results in some heavy mofos.
    You will find trying to get shot into the columns a challenge, it's slow going. I drilled out the plate wings at the top to speed up the process.
  • teekay0007
    teekay0007 Posts: 2,289
    Good get! I'm lovin' my UF26's here, too! They are the perfect stands for the LSiM703s. Mine are filled with sand and they are very solid, about 25# each.
