PSW10 fuse
My PSW10 subwoofer stopped working after few hours use, upon opening the amp board on the back, I came to know the fuse has blown, rest of the board shows no damage on visual inspection, what the spec for for the replacement. Anything else I have to investigate before replacing the fuse?
Answers
  • [Deleted User]
    Hello,
    Assuming you have the 110V version of the sub you would use a 2.0A/250V time delay fuse (if you are in a country that operates at 230V, then the fuse is 1.0A/250V). If the blown fuse has a simple break in the fuse wire then trying a replacement is a good idea. If, however, the fuse looks heavily blackened on the inside of the glass then there is, probably, a problem with the amplifier and a new fuse will simply blow again. In that case it would be best to contact Polk's CS department at 1-800-377-7655 or via email to polkcs@polkaudio.com. Have the unit's serial number and place and date of purchase handy when you contact them.
    They will get things working for you.
    Regards, Ken
  • rickmsw
    rickmsw Posts: 1
    Where do you get this kind of fuse? I picked up a 2.OAmp/250V fuse from an audio store (nothing said to them about a time delay fuse as I didn't know about that - just assumed that the 2Amp/250V fuse would do the trick) , made sure the power switch was set to off, put it in and it immediately blew when I plugged it in, after a brief hum. Or am I looking at a problem with the amplifier? The date of manufacture on this sub is August, 2017. I bought it new perhaps 3-4 years ago, can't remember, and no longer have a receipt anywhere that I can find. Thoughts, suggestions?
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,348
    Usually the problem is with the amplifier. Try and find out when you bought it since it comes with a three year warranty.
    F1nut Posts: 52,204
    rickmsw wrote: »
    You have a bad plate amp.
