What if I turn up the gain on this A31?
Does it just get louder? I forgot that it has this adjustment.
  • afterburnt
    afterburnt Posts: 7,892
    so no free lunch?
  • Why ask the question when the equipment is in front of you? Have an ounce of courage and try something by yourself.
    If you do not own it and researching, that is different and understandable.
    Wow. Just effin wow.
  • what did you expect to gain?
  • afterburnt
    halen wrote: »
    Cause I dont like **** with **** I dont know about
  • afterburnt
    Second i dont have a problem breaking other peoples ****
  • afterburnt
    Thanks for the help bucko
  • mikeyb128
    mikeyb128 Posts: 2,885
    Agreed. Read the manual, try it, you won't break anything by trying. Unless you're wasted and like my friend brant, that happens to break everything while he's drunk.
    2 channel:
    Theater:
  • afterburnt
    nb, the manual did not make it all too clear to me what it was for plus I read this elsewhere "To the left of the input options rests a gain knob that gives you control, plus or minus 6dB off normal or THX reference, to help level match the A31 to other amplifiers - presumably ones that fall outside of the Halo lineup of products. This is a decidedly pro feature" and I am certainly not a pro so I figured it is best to ask first. Instead of blowing something up.
    Just be clear you turned up the gain on the AVR and it eventually failed?
  • mikeyb128
    My benchmark has adjustable xlr pads, similar to gain adjustment. From factory at a 1/4 volume my system was blasting. Needed to adjust the jumper pads down, just like gain, to accommodate your amplifier. Just try man.
    2 channel:
    Theater:
  • afterburnt
    What effect does that have onsq? The manual warns of possible speaker damage
    pitdogg2 Posts: 27,549
    Turn it to 11 and forget about it.......
  • I think the nbrowser ear test is a good one if someone besides yourself may fiddle with your rig.
  • chumlie
    chumlie Posts: 8,658
    Turn the gain all the way up and let the pre control the volume, It's that easy.
  • Turn it up and forget about it.
  • First off, I like questions cuz they make me think. Forget about those who don't.
    You may be able to set the gain all the way up and maybe not.
    It depends on your upstream component signal. You get noise along with it.
    Most amps pass that noise on.
    msg Posts: 10,532
    edited January 2016
    I just checked this out on the A31. Unless I'm missing something, it seems a little different on this amp than other Parasounds I've messed with, which have been HCA models. THX is at 12 o'clock on the gain knobs on this A31 unit, whereas it's full clockwise on the HCA's.
    Haven't read what the manual says on this, but my initial thought, as well, before I saw the layout, was that it should be maxed for THX. Not sure what that extra 6dB will mean, or whether there's really any difference in this setting for Halo vs HCA.
    I'd read the manual here to see what it offers, but you can read it first B)
    http://www.parasound.com/a31.php
  • That is a nice amp and on the radar at one point.
    As msg suggests, reference level on the gain for that amp is zero.
    Good place to start.
  • gce
    gce Posts: 2,158
    Pretty easy to see that Normal/THX is at 12:00. Without reading the manual my guess is if you add more gain you could add more noise and or distortion, depending on how you crank the volume noob. It probably depends on what your system can take and be happy. So I would just experiment and see what sounds best to you. Hell, you might have to go to the minus side if your system cant take Normal/THX, Might sound better, you'll never know until you try.
    Anaheim Hills CA,
