Monitor 10b XO upgrade questions
[Deleted User]
[Deleted User] Posts: 0
edited January 2016 in Vintage Speakers
Finally decided to put the crossover upgrade into motion a few days ago. I opened them up to find that I seem to have two different crossovers. I'm not sure if it really matters because replacing all that anyways.
My main question is the copious amounts of hot glue covering the binding posts. I scanned over some other discussions regarding the crossovers and didn't see anybody mention running into this barbaric substitute for a lock washer. Any ideas on how to get it out of there so I can replace the posts as well?07rj2odr26wv.jpg
    pitdogg2 Posts: 27,597
    Use needle nosed pliers to pull off glue it will come off fine. I do not see any mis-match I do see different looking but same value caps. Both yellow caps are 12uf. The binding post can be switched easily you will need to enlarge the hole with better post. Better picture to see this "lock washer" either way remove glue and unscrew its that easy.
    F1nut Posts: 52,173
    Soak the hot glue with denatured alcohol and it peels right off. The hot glue is used to provide an air tight seal. Therefore, after you replace the posts you need to reseal them with fresh hot glue.
    As Ivan stated, your crossovers are the same.
  • [Deleted User]
    Cool thanks guys.
    Ok now the glue makes sense. In that case I think I'll cut out some small gaskets instead of using glue again.
    I was looking and I found that I have two sets of speakers one from 83' and the other from 87' which would explain the difference in the caps and polyswitch.
    There is no reason to not use the hot melt glue it works very good and also keeps the nut from coming loose.
    Toolfan66 Posts: 18,292
    Hey Brian, what they all said... Even putting hot glue on your new caps, and resistors will help in vibration..
    Do you need to borrow my soldering station??
    F1nut Posts: 52,173
    Larry, I wouldn't put hot glue on a resistor as it will impede its ability to disperse heat.
    edited January 2016
    True at one time there was a great picture of what happens when you do, but it was on the old forum. 3 m, locktite and scotch make great 2 sided high bond tape to use if you so desire for all but resistors if you do not want hot melt glue
  • RandyCroissant
    Stand the resistors off the board either on end or give em a little room when mounted flat. They generate heat enough to burn the board when driven hard.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • [Deleted User]
    Toolfan66 wrote: »
    That'd be a big help! I won't need it for a couple weeks though. I'm still slowly ordering everything I need.
    F1nut Posts: 52,173
    Yep, I mount them slightly off the board with a very small piece of 3M VHB tape at either end. That allows for good air flow while providing damping.
    Don't know what I was thinking, that's how I have always done mine as well.. :-(
  • [Deleted User]
    What about adding some silicone to each end? I have a tube of that.
  • [Deleted User]
    nbrowser wrote: »
    ER308L wrote: »
    Silicone is bad on metal...offgassing causes corrosion on the drivers themselves and electrical connections.
    Well it sounds like the best option is a small gap and that 3M tape.
    Silicone and electronics is a bad thing..
    F1nut Posts: 52,173
    Toolfan66 wrote: »
    Brain f a r t........a sure sign you're getting older. ;)
    I have a hot glue gun you can use on your capacitors, I think I have some of that 3M tape as well..
    Brian, after you do this first set of speakers you will be hooked, and learn a bunch. I will help you as you go along if needed..
    Toolfan66 wrote: »
    No doubt, big 50 in a few days :|
  • ken brydson
    ken brydson Posts: 9,063
    Toolfan66 wrote: »
    Toolfan66 wrote: »
    Punk kid.... ;)
