TT Isolation Base and Amp Stands
I recently picked up a 24x18x3 Maple Butcher Block through Amazon to utilize as an Isolation Base for my TT.
There was a previous thread about this very thing. http://forum.polkaudio.com/discussion/170558/diy-tt-isolation/p1
I decided to trim an inch off of both ends of the huge block to remove the "built in" handles and to make it fit the top of my rack a little better.
Sanded, stained and finished
Installed some Sorbothane Vibration Pads between the rack and the block
And here's how it turned out
Liked the big Butcher Block soo well that I picked up two more smaller ones to use as Amp Stands, made base for the Blocks, stained and finished also.
Here they are doing their job getting the amps off the floor
Also recently install Larry's Ring in the 2.3TL's (had Hurricane Nuts previously) and installed some new Spikes under them, both of these mods have made a noticeable impact on their presentation, along with isolating the TT, everything has been "Kicked Up" a notch!
Have more Winter projects in mind, but for now I'm going to enjoy Holidays and get my listen on!
  • mikeyb128
    mikeyb128 Posts: 2,885
    Looks sweet! The color is a great match to your rack. Me likey :smile:
    2 channel:
    Theater:
  • BlueMDPicker
    Awesome job! That's a great looking setup. Bet it sounds better than it looks.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    mikeyb128 wrote: »
    Thanks, I used the same stain on both the rack and the Butcher Blocks, the Blocks came out a little darker as the Maple absorbed the stain more than the Poplar shelving on the rack.
    If you ever get back home (KC) I'm right on your way in Columbia, give me a shout!
  • hochpt21
    hochpt21 Posts: 5,423
    Wow, that is stunning.
  • gce
    gce Posts: 2,158
    Nice, good looking setup you got there.
    Anaheim Hills CA,
    HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
    SCompRacer Posts: 9,195
    High marks on the DIY and color coordination!
  • Mike Reeter
    Thanks for the kind comments, after several years I'm finally getting my stereo where I want it.
    The Isolation Block and the Amp Stands were much needed additions that did'nt cost an arm and a leg, the kind of improvements I like ;)
  • voltz
    voltz Posts: 5,384
    Nice job Mike! The Amp stands really took it to another level.
    msg Posts: 10,584
    Wow! Beautiful! Really nice job on those.
    Which turntable is that? I'm new at this and becoming a sucker for tables that can use periphery rings/clamps.
  • aprazer402
    aprazer402 Posts: 3,451
    Very, very nice Mike. One question, your OP states "Sanded, stained and finished". I'm assuming you used a wiping stain. when you say finished does that mean you put a finish over the stain (polyurethane)? It looks good either way, no gloss, satin gives a nice low sheen.
  • Mike Reeter
    edited December 2015
    Thanks, the table is a VPI Classic 1 with a VPI Periphery Ring and clamp.
    The ring and clamp combo is a good step up in presentation, and flattens warped Vinyl ta boot!
    Post edited by Mike Reeter on
  • Mike Reeter
    aprazer402 wrote: »
    You are exactly right, I used a Satin Poly after staining, I've never tried the "all in one stain and finish coat" that's available now, guess I'm too old and set in my ways!
    I thin the Polyurethane and spray it on, I have a small Pancake Compressor and and Automotive type paint gun, a cheapo but it works fine for this kind of work.
    I usually spray about 3-4 thin coats, rubbing out a little between coats, the only downside to the Poly is the dry time, Lacquer is much quicker to dry, but the fumes are dangerous if you don't have the proper room.
  • aprazer402
    Awesome. The all-in-one stuff is NO good IMHO.
  • Mike Reeter
    aprazer402 wrote: »
    I've never tried any Water Based Finish yet either, but I might one day.
  • jeremymarcinko
    Very nice. The amp stands look pretty great.
    gudnoyez Posts: 8,197
    Nice job very attractive 2 channel rig time to sit back and enjoy the fruits of your labor.
    ... I've never tried the "all in one stain and finish coat" that's available now, guess I'm too old and set in my ways!
    I prefer to stain and finish separate too. I've seen that all in one stuff used when folks wanted their door/baseboard moldings darker.
    I've been using water based poly with good success. I started using it on our Oak window sills after the sun beat up on the lacquer finish. Still holding up very well, cat tested. I also used water based poly on the maple I wrapped my turntable with.
    But walnut gets Tung oil. ;)
  • Mike Reeter
    SCompRacer wrote: »
    Hey Rich, Glad to hear the Water Based products have performed well for you, that's more than a "Top Shelf" endorsement for me!
