Pangea AC-9 2m
EndersShadow
Liked this cable, decided I wanted to try something different. Was a great cable for my amp as I had NO DOUBT that I was not going to have problems pulling ANY amount of power from the wall with this thing.
This is a regular AC-9 NOT a SE or MKII model
Great cable for a multichannel or stereo amp.
Costs INCLUDE SHIPPING. Payment via PayPal Gift or add 3% to cost. Likely to cost me 20 bucks to ship and insure this given its weight and size.
Pangea AC-9 2m - 110
Specifically Designed for High-Current Components
In spite of its name, Pangea Audio's AC-9 high-current power cord isn't a nine-gauge cable. It's actually a seven-gauge cable, which means it's even heftier than the nine-gauge! (The lower the gauge, the thicker the cable.) This explains why our customers have been so wildly enthusiastic about the sound of AC-9. This difference is especially noticeable in the bass, where the AC-9 outperforms every cable we're heard under $200, and most cables under $500.
The AC-9 has been designed specifically to deliver the high current needed by mono, stereo, and integrated power amplifiers. It's also ideal for powered subwoofers and makes a great choice for use with high-current-demanding line conditioners. Its combination of superior materials, advanced geometry, and noise-fighting shielding enhances the performance of connected components.
Because of their high-current requirements, power amps benefit from heavier gauge conductors than normal power cords offer. Although the AC-9 uses large-diameter conductors, it requires less shielding than power cables that are designed for use with source components. Therefore, the AC-9 offers greater flexibility than other heavy-duty power cables. That makes it kinder to your gear and easier to work with.
"You Don’t Always Have to Pay a Lot to Get a Lot"
"The AC-9 is a perfect example of the adage that you don’t always have to pay a lot to get a lot, notes Sean Fowler in his April 13, 2010 review for SonicFlare.com. "As I listen to the AC-9, I struggle to think of a time when I heard any other affordable power cord deliver such a natural presentation without committing some kind of damning caveat."
Superior Noise Rejection
The AC-9 boasts 99.99% purity OFC copper conductors for maximum conductivity. Its 7-awg construction facilitates high-current power delivery, while its five-way multi-gauge geometry optimizes 50/60 Hz AC power.
Counter-spiraled conductors offer superior noise rejection. Double-shielded provides high-current noise isolation. Special two-shot molded connector bodies protect vital AC connections for maximum current delivery and long life, while 24k gold-plated contacts provide superior electrical contact.
Pangea Audio Power Cables
Pangea Audio power cables offer the perfect balance of power, shielding, and flexibility for audiophile components. These cables have been designed, not from the AC wall outlet to the component, but the other way around – from the component to the wall outlet. The result is a cable that not only fully satisfies the 'real power requirements' of audiophile components, but which also delivers improved performance for both power and component isolation.
Pangea's 'component to the wall outlet' design results in a better cable that's designed just for the component you want to power. The cable gives you precisely what you need - no more and definitely no less.
When More Is Sometimes Actually Less
Until now, all upgrade power cables have been designed according to a 'more is better' philosophy, leading manufacturers to increase the diameter of the conductor and the thickness of the insulation in an attempt to improve performance, but at the expense of flexibility. The resulting thick, noncompliant cables put a severe strain on the chassis of connected components.
Heavy, inflexible cables can also reduce the effectiveness of component isolation and suspension systems. Because power amps do benefit from heavier gauge conductors, the AC-9 is thicker than its smaller sibling, the AC-14. However, it is only as thick as it needs to be for maximum performance, and it is still more flexible than competitive cords.
Bump"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
So it appears this might actually be a AC-9SE and not just the original AC-9.
Price remains the same....."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I would like this, pm meSamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
While I consider on whether to go all shunyata or not, I am gonna pull myself from the running so this sale can move forwardSamsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
bump bump, buy my stuff"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
The ac9 is for amps and would work very well. The ac14 is more for source components.
Hope this helps -
^what he said
The AC-9 is a 3 X 7 gauge cable. The thing screams poweramp. It's as thick as a standard garden hose... And I'm not joking either lol."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
SOLD"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
