SDA 1 Interconnect Cable
I have a pair of SDA 1's with no interconnect cable. The plug is a pin and a blade. Can someone tell me if the cable is available somewhere or if the plugs are common enough to build the cable myself? And if not, what my options are?
Thanks,
Dale
    F1nut Posts: 52,152
    Dale, the pin/blade cable is no longer available. Your best option is to replace the sockets on the binding post plates with SpeakOn sockets, then use SpeakOn connectors and high quality speaker cable, preferrably the same high quality cable you use for your speakers to make a new SDA cable. If this is something you don't want to or can't do, talk to Westmassguy.
