AVR powered zone 2/3 VS dedicated amp stereo setups?
Shopping for a new AVR and it appears that none support 7.1.4 Atmos/DTS:X and a powered Zone 2/3 output at the same time. This has me thinking..should I just ditch my zone 2/3 and wire those two zones independently with all the controls and a speaker level input in their own respective rooms? The only thing that either is used for is audio.
Too many good quotes to list..waiting for some fresh ammo. :)
  • DaveHo
    DaveHo Posts: 3,581
    Does the receiver you're looking to buy have pre-outs for the remote zones? If you already have the speaker wire run to the remote zones, why not pick up a couple two channel amps or a single amp & a speaker selector? I have 4 remote zones all powered by two spare channels on a 7 channel amp & routed through an Adcom GFS-4 selector. With all the new receivers being network capable, control of the remote zones is accomplished via an Android app from my receiver manufacturer, Pioneer. Works well for me.
  • villian
    villian Posts: 412
    Generally they do seem to have pre-outs at least. But I don't think they can process those channels, even via pre-out, while Atmos or DTS:X is active in a full 7.1.4 setting. But I suppose I could just pick up an old cheap AVR to use for the other rooms and stash it next to the main AVR. The zone 2/3 rooms are nothing special, so I'm not worried about getting absolute sq.
    tonyb Posts: 33,065
    I don't think you'll find a receiver anywhere with separate amps to power 2 more zones. If the other zones are just used for music, buy a couple small footprint class d amps to power speakers in other rooms. Your source for music will do the processing such as a cdp, streamer, etc.
    If you want to play movies though in those other zones, that's a different animal.
  • villian
    villian Posts: 412
    tonyb wrote: »
    Why are all the AVR manufacturers advertising fully assignable amps then? This is what I don't get.. Because from what it looks like you can't actually assign anything to power zone 2 except the Surround sides/surround backs/or atmos speaker outs?? I have everything externally amped except my SBL/SBRs.. So can I just find something that will let me assign the FL, FR, C, SL, or SR amps to use for the zone 2/3 or atmos speakers?
    tonyb Posts: 33,065
    They are assignable....in zone 1. Nothing I'm aware of will allow you to re assign zone 1 amplification in a receiver to zone 2 or 3.
    Why not just wi-fi music to those rooms ?
  • I currently use a separate 2 channel system for zones 2 and 3. I use the tape out on this system to the CD in on the AVR to get music to all 3 zones. I also have a smart BDP on the 2 channel system for steaming Pandora to all 3 zones.
    What's your current AVR?
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
  • villian
    villian Posts: 412
    Yamaha RX-V667
    I'm searching for an Atmos/DTS:X replacement, but apparently there are none that can do what I need.
    7.1.4 Speaker Setup
    (I have FL, FR, C, SL, & SR on external amps so I only need an AVR that has assignable amps for the SBR, SBL, 4 height speakers, and preferably zone 2/3)
    1.4v+ Pre-Outs or XLR pre-outs
    Zone 2 support w/HDMI/Digital Input Decoding for Zone 2
  • villian
    villian Posts: 412
    Yamaha RX-V667
    7.1.4 Speaker Setup
