Suggestions for DIY project- amp/integrated?
So, due to my future upcoming move and what not I'm not looking to buy anything right now but have always been interested in the DIY options. I'm not planning on starting anything until after the move so would like to use this time to figure out what I want to do.
So to start, the speakers are going to be horns I would be pairing anything with. Either I was going to be doing Klipsch or may go a DIY route for this as well as I have ideas of things I would like to try.
That being said, I would be more geared towards the tube route. I've looked at bottle head stuff but thats upwards of $950 for their 2 channel amp. It would be a fun starting point but wanted to see if there are other suggestions for either other low wattage tube amps, or an integrated project that wouldn't be terribly difficult or a ton of work for someone that is new to DIY.
I've looked at Pass DIY and looks fun but not sure if SS is the direction I want to go right now. I've honestly never heard Pass on a horn so it might be a good combo but figured I would stick with tubes on horns as that is always the combo I enjoy.
Also even if this isn't a kit etc I would be interested in hearing suggestions for maybe an old integrated that would need a rebuild etc. Might be a good way to start. I'm open for ideas so let me know what you guys think.
    SCompRacer Posts: 9,152
    Check out the diyaudio projects store.
    http://diyaudioprojects.com/
    Bottlehead stuff is great though, hits way above it's price point. Top notch instructions too. You will encounter high voltages even with low output tube gear..so must be careful.
    This is right up mhardy's area of expertise, so I'm sure he'll chime in.
  • cstmar01
    cstmar01 Posts: 4,424
    Thanks Rich! I do like the Bottlehead designs and overall think they make a great kit. I just really wanted to see what else is out there that would be comparable and go from there.
    heiney9 Posts: 25,580
    Any of the First Watt DIY stuff will sound fantastic on horns. This is not a light endeavor and with most of Pass stuff he will guide you, but you must have an understanding of how circuits work.
    What I'm saying is you need to know your way around a power supply and amplification circuits beyond just being able to read a schematic. His projects and guidance assumes an intermediate understanding of electronics.
    It's not a "paint by number" type of thing.
    That being said I've always wanted to tackle one of the EleKits since they are pretty much "paint by number" and allow several specific choices of upgraded parts depending how far the rabbit hole one wants to go.
    http://www.positive-feedback.com/Issue45/elkit.htm
    http://www.vkmusic.ca/elekitnew.htm
    https://www.tubedepot.com/products/elekit-tu-8200-stereo-tube-amplifier-kit
  • I've had fun and 100% success/satisfaction building several of Bruce Rozenblit's designs to drive high efficiency speakers. Great instructions and support IMHO. Check them out at Transcendent Sound.
    300B OTL System
  • cstmar01
    heiney9 wrote: »
    Thanks for the info Brock. Seeing it's going to be my first endeavor I would like something a little easier. I'll check out the EleKits as I haven't heard of them before and sounds more like my thing.
    Good to know about the combo as I've never had the chance to get my ears on it. I've heard some terrible pairings of SS with horns that was unbearable but if you get a good pairing it can sound awesome. I'm still a huge fan of the Soundlabs I had but just figure I would try something else.
  • cstmar01
    300B OTL System
    Wow. Those look amazing and congrats on the build! I'm going to check these out for sure!
  • cstmar01 wrote: »
    300B OTL System
    Thanks! But, that system is off the Transcendent site to whet your appetite. I built a couple of the smaller, single-ended OTL amps, the grounded grid pre and the power conditioner.
    Chris, I forgot. You can also check out Park's Audio PCB kits. Look under diy projects. I have his Budgie SUT in my vinyl rig. Excellent SQ, reasonably priced.
    http://parksaudiollc.com/
    nooshinjohn Posts: 26,064
    Check out the kits from AudioNote. I was going to jump all over them. VERY high end kits...
    http://www.ankaudiokits.com
  • cstmar01
    SCompRacer wrote: »
    Thanks Rich!
    These are very nice looking and I'll have to do some further research on them. Some nice looking monos however but a little more than what I'm looking to spend on a DIY project at this point but seriously some nice looking gear.
