Tube Questions
could you tell me a list of maybe 10 different tube's to look for that may be worth messing with - as i just picked up 20 shoe size boxes of tubes. Not sure what they were used for -or- can be. Different sizes & pin design's. I paid dirt cheap for them & they came with a old tester that is problably way outdated & may not even work/or calibrated. I am gonna try to go thru 1 box a night if i can & not sure if i will get them tested at all + i dont know how to even if it did work. Just want to try to maybe learn something out of this.... I brought one box in & will take a look. TIA .. if for some miracle there is something that can be used & you need it i will be glad to send them to you if you pay shipping. Not sure when the last time tester was used & i have NOT even cleaned it up - or plugged it in5i1mobwzi4n6.jpeg
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
  • boston1450
    boston1450 Posts: 7,758
    There were boxes that had some numbers wrote on them. I will post pics & there were alot that had no written on them. Maybe this may help. Oh there were boxes the tubes were loose inside the box. Would they still be usable ?
    Randy-Maine
    by David WMG
  • boston1450
    Randy-Maine
    by David WMG
  • boston1450
    Randy-Maine
    by David WMG
  • boston1450
    Randy-Maine
    by David WMG
  • boston1450
    edited November 2015
    I saw Tung Sol. Rca. Sylvania's & lots more different brands. Not sure if tv or audio. It gets dark up here early so i didnt spend much time with them tonight & can report back
    Randy-Maine
    by David WMG
  • Polkie2009
    Polkie2009 Posts: 3,834
    I'm going to guess the variety of tubes you got there would work with tube audio gear, guitar amps and preamps, tube TV's, any old tube gear? Hope the tubes are all good and still work. :)
  • boston1450
    I have no idea. I know the tester is dusty & screws are rusty. The tubes in boxes appear to be clean. Some boxes are mixed together. I plan on cleaning up the tester tomorrow & poke around with it some. It was store in house & gentleman passed away & guy i got them from knew nothing about them & wanted them gone
    Randy-Maine
    by David WMG
    SCompRacer Posts: 9,149
    Here is a pdf assembly and use guide for it. Link is from antique radio forums. Some good info in the linked thread. I wouldn't plug it in without inspecting the innards first.
    http://www.antiqueradios.com/forums/viewtopic.php?t=126881
    http://www.jogis-roehrenbude.de/Roehren-Geschichtliches/Roe-Pruefer/Heathkit-IT21/Anleitung.pdf
  • boston1450
    Thank you for info. I will get some read on. I have someone local i can bring it in & have him take a peek. Thanks again
    Randy-Maine
    by David WMG
    pitdogg2 Posts: 27,551
    any 6sn7's or 6BX7 or 6BL7?
  • boston1450
    Thank you Appreciate
    Randy-Maine
    by David WMG
    well keep me in mind if you find some any of those in pairs Randy.
  • boston1450
    I will Pit hope to get to some tonight will report back
    Randy-Maine
    by David WMG
  • MrBuhl
    MrBuhl Posts: 2,419
    Because I have amps/preamps that use them, these all come to mind:
    12ax7 & variants
    12au7 & variants
    6Ca7/EL34 and variants
    6DJ8 and variants
    also:
    EL84 and variants
    KT-66
    If you checkout Brent Jesse's pages, you can see a general listing of the variants of these tube types and his take on sound/value of brands if you click the main tube type heading.
    http://www.audiotubes.com/
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • Don't forget the 6L6's
  • boston1450
    Thanks guys. I will be looking some over tonight & the weekend. I hope to have a few good ones in the bunch & if i dont i hope someone local can use them. I dont know much about tubes. But if i can save them from the dump & someone can use them thats great. Will report back later tonight/tomorrow on this. TGIF
    Randy-Maine
    by David WMG
  • boston1450
    Oh. Big help on the size - numbers. Thank you
    Randy-Maine
    by David WMG
