Couple Pangea cables
EndersShadow
Looking to move to some other Powercables so time to sell these off. I "think" I might have the boxes for these but not sure. I know I have the box for the AC-14SE...
For sale is a Pangea AC-9SE 1.5m and a Pangea AC-9 2m powercable. I've also got a Pangea AC-14SE 1.5m that for the right price I might let go as well.
I'm fairly firm on the listed prices for these as well. These are fairly heavy cables and will cost a little bit to ship. All three cables are in very good condition and I will try to get some photo's of them tomorrow.
Pangea AC-9SE 1.5m - 175
Tighter Bass, Better Image Focus, and Other Benefits
The Pangea Audio AC-9SE Signature Edition power cable is an enhancement of Pangea's wildly popular AC-9 power cable. This 7-awg design with its advanced combination of Litz, PCOCC, and other conductors offers a substantial upgrade compared to the already excellent AC-9. The sonic benefits of the Signature Edition include tighter bass and better image focus.
Because of their high-current requirements, power amps benefit from heavier gauge conductors than normal power cords offer. The AC9-SE is specially designed to deliver the clean, high-current power needed by audio amplifiers – including stereo, mono, multichannel, and integrated amps. It is also ideal for powered subwoofers, power conditioners, and other high-current electronic components.
OFC, Long-Crystal Copper, and PCOCC Copper Conductors
The AC-9SE uses different wire gauges consisting of a combination of OFC, Long-Crystal Copper, Litz, and audiophile-grade single-crystal PCOCC (Pure Copper by Ohno Continuous Casting) from Japan. PCOCC (99.99999% pure) Ohno-cast copper conductors are typically ten-times more expensive than standard copper conductors.
Counter-spiraled conductors offer superior noise rejection, and the triple-shielded design provides high-current noise isolation. The large-diameter 7-awg construction boasts seven-way multi-gauge geometry optimized for high-current delivery of 50/60 Hz AC power. The 24K gold-plated contacts provide superior electrical contact.
Pangea Audio Power Cables
Pangea Audio power cables offer the perfect balance of power, shielding, and flexibility for audiophile components. These cables have been designed, not from the AC wall outlet to the component, but the other way around – from the component to the wall outlet. The result is a cable that not only fully satisfies the 'real power requirements' of audiophile components, but which also delivers improved performance for both power and component isolation.
Pangea Audio's 'component to the wall outlet' design results in a better cable that's designed just for the component you want to power. The cable gives you precisely what you need - no more and definitely no less.
Pangea AC-9 2m - 130
Specifically Designed for High-Current Components
In spite of its name, Pangea Audio's AC-9 high-current power cord isn't a nine-gauge cable. It's actually a seven-gauge cable, which means it's even heftier than the nine-gauge! (The lower the gauge, the thicker the cable.) This explains why our customers have been so wildly enthusiastic about the sound of AC-9. This difference is especially noticeable in the bass, where the AC-9 outperforms every cable we're heard under $200, and most cables under $500.
The AC-9 has been designed specifically to deliver the high current needed by mono, stereo, and integrated power amplifiers. It's also ideal for powered subwoofers and makes a great choice for use with high-current-demanding line conditioners. Its combination of superior materials, advanced geometry, and noise-fighting shielding enhances the performance of connected components.
Because of their high-current requirements, power amps benefit from heavier gauge conductors than normal power cords offer. Although the AC-9 uses large-diameter conductors, it requires less shielding than power cables that are designed for use with source components. Therefore, the AC-9 offers greater flexibility than other heavy-duty power cables. That makes it kinder to your gear and easier to work with.
"You Don’t Always Have to Pay a Lot to Get a Lot"
"The AC-9 is a perfect example of the adage that you don’t always have to pay a lot to get a lot, notes Sean Fowler in his April 13, 2010 review for SonicFlare.com. "As I listen to the AC-9, I struggle to think of a time when I heard any other affordable power cord deliver such a natural presentation without committing some kind of damning caveat."
Superior Noise Rejection
The AC-9 boasts 99.99% purity OFC copper conductors for maximum conductivity. Its 7-awg construction facilitates high-current power delivery, while its five-way multi-gauge geometry optimizes 50/60 Hz AC power.
Counter-spiraled conductors offer superior noise rejection. Double-shielded provides high-current noise isolation. Special two-shot molded connector bodies protect vital AC connections for maximum current delivery and long life, while 24k gold-plated contacts provide superior electrical contact.
Pangea's 'component to the wall outlet' design results in a better cable that's designed just for the component you want to power. The cable gives you precisely what you need - no more and definitely no less.
When More Is Sometimes Actually Less
Until now, all upgrade power cables have been designed according to a 'more is better' philosophy, leading manufacturers to increase the diameter of the conductor and the thickness of the insulation in an attempt to improve performance, but at the expense of flexibility. The resulting thick, noncompliant cables put a severe strain on the chassis of connected components.
Heavy, inflexible cables can also reduce the effectiveness of component isolation and suspension systems. Because power amps do benefit from heavier gauge conductors, the AC-9 is thicker than its smaller sibling, the AC-14. However, it is only as thick as it needs to be for maximum performance, and it is still more flexible than competitive cords.
Bump...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Bump.... make me an offer if your interested in one or more of the cables... You never know, I might just say yes....."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Ok, Lets try to make a deal here.
250 shipped CONUS and I throw in the AC-14SE 1.5m as the icing on the cake. Thats 3 good decent length powercables ladies and gents....EndersShadow wrote: »
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
BUMP
Willing to split and sell each one individually. PM me for pricing."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Split the package apart. Still open to a single buyer for all three."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
you don't happen to have the AC-14 still available?Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
Sorry man that sold to a member here a few months bsck"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
sorry... I tried finding it but must have missed it. Thanks.Polk Lsi9
Keces DA-131 mk.II
It is I who misread. I have the .6m AC-14 still. Pm me
