polk 6200 and psw250
mbryson
Hi everyone, Im sort of starting at the bottom with this system, but I am very happy with everything! Can you help me.
Option #1 for the sub says to set front spearkers to large and set the sub to none. I havent experimented yet, does this really work better. regards mac:)
Post edited by mbryson on
if you have the front's wired through the sub, yes, this would be the optimal way to set up the reciever...
if your sub is not wired through your fronts then no.. use the sub-out jack.. set your speakers to small and let your sub handle all the bass, if it can... also depends on how large your mains are and what there range is, if they only go to 80hrz or 120, then set them to small..... if they can go down to 30 or 40hrz then set them to large, and set the crossover on the sub to as low as it can go try and get under your mains..... you might want to try the sub off for music, depends on your taste and listening preference..
