Help w/ Carver C-2
acdds
I just received my Carver m1.5t and a C-2 pre-amp. The preamp won't power up. Uncovered it and the fuse is good and I can't see any burn marks on the circuit boards. Any suggestions?
Receiver = Denon AVR-3803
DVD = Denon DV-2900
Fronts = SDA SRS 2.3TL's
(Carver m1.5t)
Center = CSi40
Side surrounds = Fxi30's
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Pioneer SX-1050 receiver
Rti38's
DVD = Denon DV-2900
(Carver m1.5t)
Center = CSi40
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Rti38's
Post edited by acdds on
First contact the seller.
It's possible the power switch is bad. Do you have a VOM?More later,
Tour...
Vox Copuli
I am in the process of contacting the seller (just haven't been able to get ahold of him today). What is a VOM?Receiver = Denon AVR-3803
DVD = Denon DV-2900
(Carver m1.5t)
Center = CSi40
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Rti38's -
Volt-Ohm-Meter... Basic troubleshooting gear for electronics.More later,
Tour...
Vox Copuli
Are you sure the lights are not just burned out in the C-2?More later,
Tour...
Vox Copuli
I tried to hook it up using every input except the phono. No sound. I have never used a dedicated preamp and it didn't come with the manual so could you please list the proper input and output? Inputs = External phono cartridge load, phono, tuner, tape 1, tape 2, external processor. Outputs = main, main 2, tape 1, tape 2, external processor, line gain (shorting plug +10db). Those are from directly off the back of the unit.
I will pick up a VOM tommorow. Where do I attach the leads?Receiver = Denon AVR-3803
DVD = Denon DV-2900
(Carver m1.5t)
Center = CSi40
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Rti38's -
When you say no sound, are you talking about through speakers via the 1.5t or other?
If you have a pair of headphones that could be the most straightforward check right now.
As for inputs, other than the phono's in, they're all the same.
Radio Shack has decent, inexpensive VOM's. As for where to check, start with the AC coming to and going out of the power switch.More later,
Tour...
Vox Copuli
