Polk TSX 330T - Is it An Upgrade over my RT800s?
I found the RT800s on CL a few months back and really like them and have them as my main speakers. I just picked up a CS400i center channel to go with it and have yet to hook it up as it won't fit in my current TV stand so getting a new one. I do need some better rears as they are just small KLH bookshelf speakers. I found the TSX 330Ts for $200 and thought they might be nice for the rears but would they be better in the front and if they are will the CS400i center go with them okay? Thanks for your help and if the TSX won't go for rears what would you recommend I look for? My setup would be mainly for movies.
  • lendon
    lendon Posts: 30
    Thanks for the reply. I know the surrounds do not matter as much to match but I was trying to if possible. I had R50s for the rears but sold them and wanted to get something that would sound better then towers for the surround maybe bipole/dipole speakers.
    I just missed out on a pair of Fxi30 Polks locally for $60 that probably would have done well for me but those Mordaunts you posted look nice too. I look on Craigslist often here in Phoenix and usually come across things if I am patient and look hard enough.
  • lendon
    lendon Posts: 30
    I also have been seeing the Fxi A6s on Ebay for around $200-$250. They look like they would be an excellent choice also.
  • lendon
    lendon Posts: 30
    I looked around for the FX 500s and no luck, good looking large surround speakers though. I wonder how they compare to the FXi A6?
