Another Amp question
AsSiMiLaTeD
Does anyone here have an opinion on using the H/K PA2000 to bi-amp my 150s. I just bought one from Carlos via the flea market, still trying to decide if I can use it to power the 'subs' in my 150s along with the AVR80 powering the mids and highs.
Some of you may remember me going through this ordeal a month or so ago and deciding on the Adcom 545. Well I got it in from a seller on Ebay and it was in terrible shape...I didn't even plug it in, the thing looked like it had been dropped from a two story building, not at all the amp that was described in the auction.
Anyway, so now I'm searching for a new amp again and I thought I'd grab the H/K from Carlos. I figured if it won't do the fronts very well, I can always use it for side speakers later...
Anyway, anyone have any thought on using it to Bi-Amp the 150s?
Post edited by AsSiMiLaTeD on
Sorry to hear about the Adcom...
Only thought on the PA2000 is the obvious, give it a shot. I would think that it is likely to be a better match for your AVR than the Adcom would have been.More later,
Tour...
Vox Copuli
