Hooking up laptop to receiver
Hi all I would like to hear some opinions about what would suit best for my application or how i should go about setting it up. I have a Denon Avr-3000 w/ audio video standard RCA jacks + s-video, no HDMI. A Origin EON17s with standard audio outputs + 1 HDMI. Sony Vizio M422i-b1 w/ ethernet, dtv, audio output (red, white), optical audio out, 4 HDMI, component (red, blue, white, green), usb. I plays games from the laptop and would like to connect it to the receiver to the tv. Now should I get a convertor from the laptop to reciever the analog to tv? Or use the audio jacks on the laptop I heard the quality of sound takes a big decrease. What's the best way to go while maintaining sound quality?
  • erniejade
    erniejade Posts: 6,321
    You can find inexpensive usb dac's like the Audioquest dragonfly or LH labs Geek that will sound way better then the built in sound card on the laptop. The 2 I mentioned would plug into your laptop usb, then you can take a cord and go from the dac to your receivers input.
    What kind of cable box or how are you receiving your TV signal?
  • 885yam
    885yam Posts: 7
    Tv through wifi only. No cable box don't feel like flushing money
  • 885yam
    885yam Posts: 7
