Marantz NA7004 Nework Audio Streamer
This is an awesome little unit. Works great streaming from the computer, works great as a DAC, and I mainly used it for Pandora. Still selling demo models at Music Direct for $399. This is a great deal at $200 plus shipping to anywhere!
The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects
    EndersShadow Posts: 17,704
    Great Item and great seller here folks!
  • JuanR
    JuanR Posts: 718
    Ill give this a try...pm sent
  • trav0810
    trav0810 Posts: 1,056
    Looks like this unit is sold folks...too slow!
    Thorens TD320
    Modified Carver C-1
    Thank GOD! I was close lol
  • deronb1
    deronb1 Posts: 5,021
    Wow! Great price! Congrats Juan. You'll love it.
  • rooftop59
    rooftop59 Posts: 8,121
    Assuming this is sold?
    Game Room 5.1.4:
    Bedroom 2.1
  • deronb1
    Th8nk JuanR snatched it up
  • maingey
    maingey Posts: 632
    I think so also.
  • deronb1
    Have you had a chance to hook it up yet Juan?
  • JuanR
    JuanR Posts: 718
    I tried the USB, it sounded great! I'm having a little trouble getting Pandora and the Internet Stations to work. I'll try and troubleshoot it some more over the next few days. My busy work schedule only allows me very little tme on it but I will get it somehow.
  • trav0810
    Really? Pandora opened right up for me. That was the only internet radio I used and it required nothing more than setting the input to Pandora and hitting enter.
    Thorens TD320
    Modified Carver C-1
  • deronb1
    Not to insult, but it doesnt have built in wi-fi. I got a refurb netgear adapter on recommendation from a member here and it works great.
  • trav0810
    Correct. I ran mine wired directly to my router.
    Thorens TD320
    Modified Carver C-1
  • JuanR
    JuanR Posts: 718
    edited November 2015
    I'm going to take this to PM, I have tried a couple different cables from my internet modem straight to the Marantz with no avail...
    Juan
  • Nightfall
    Nightfall Posts: 10,084
    JuanR wrote: »
    Juan
    Is the Marantz getting an IP address via DHCP from the router?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • JuanR
    JuanR Posts: 718
    I tried both methods with DGCP ON and inputting the address manually with DHCP OFF node.
    Interestingly, with DGCP ON I get a SUCCEEDED connection, but when I change it over to Pandora afterwards, I get an Internet connection fail.
    With manual DGCP OFF, I can not get it to connect at all.....
    I tried a hard reset on the unit (the manual explains how to do it) but nothing changed afterward, still getting same results.
    I have also tried updating the software and no luck both ways, but with DHCP OFF I get a connecting to the internet screen that never really does, I left it running overnight to wake up to the same screen.
    Thanks for your help,
    Juan
  • JuanR
    JuanR Posts: 718
    just to clarify, the software update was unsuccessful both ways...
  • maingey
    maingey Posts: 632
    Did you guys figure this out?
  • My neighbor had the same issues. He ended up.returning it.
  • trav0810
    It's crazy. He can get it to work through the USB, but not the Ethernet. I never had a single problem. I offered to take it back, but he decided that he is going to keep it and just run it through the USB
    Thorens TD320
    Modified Carver C-1
  • deronb1
    Try a wireless adapter
  • maingey
    maingey Posts: 632
    or since there is a problem with it being assigned DHCP can you manually enter in the ip/subnet etc onto it? I sounds like the unit isn't seeing the gateway.
