New to audio- What amp should I get for (2) MM10's
agular9
Well, I'm looking to hook up my two MM10 subs in my trunk, but I have yet to pick out an amp to power them. Which carbon polkmomo amp should I get?
The subs say they take max of 1000 W...
The biggest output of any of the polkmomo amps is like 500 and to only 1 speaker... and the others are only like 220 to two and 200 to like 4.
Which amp should I get? I don't really want to get two amps. Should I look to another dealer... if so who?
Thanks, I'm a newbie
Post edited by agular9 on
You will have better luck with the Car Audio section, go to main forum page - scroll down! Good luck!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
1000 Watts is overkill for car use.
car amps that say they put out 1000 watts arent really, thats most likely their peak power and who knows at what ohm rating
