2.3's as rears in the theatre room
Scored these 2.3's .
They'r only the second set i have seen here in Australia for sale over the last 8 years
I grabbed them quickly.1 owner from new...slight damage to both tops,quite deep though ,i will chime into Jesse's posts for tips to fix or i will replace with timber!..
I have them set up in corners due to room size (20'x18').The entire room is treated with sound absorbtion tiles behind my projector screen which is set up on the 20" wall side, carpeted walls to 5' high then curtains to the ceiling pelmets.,two 8" diameter carpet wrapped bass traps and 3 corner bass traps to a height of 7'.
This room is dead..nothing but vibrations straight from the speakers
The ambiance from the SRS fronts, 2.3 rears and lsim 706 ctr which are fed by 3 x sunfire signiture series 2 amps is awesome. cant wait to install Vr3mods Thankyou Trey
I love turning electricity into vibrations. -
Congrats on your purchase. Where are you in Oz?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Thanks Drumminman , I am in Perth, Caversham 50 years.
