Treasures!
MrBuhl
MrBuhl Posts: 2,419
edited October 2015 in 2 Channel Audio
A few new treats arrived recently...
Based on heavy recommendation from Jesse - juicy delicious tube love:
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
    txcoastal1 Posts: 13,513
    edited October 2015
    Beautiful, give us a review after 40-50 hours
    F1nut Posts: 51,776
    Nice! I hope you like them.
  • Mikey081057
    Mikey081057 Posts: 7,127
    Treasures are sweet treats for sure
    Garage | Polk Monitor 5B's
  • dhart86
    dhart86 Posts: 1,594
    I will always have a set of Treasures in the House. I am sure you'll like them.......if not shoot me a pm :)
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
    F1nut Posts: 51,776
    Well, have you fired up the amp yet?
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Very Classy looking, packaging and all. If they only sound half as good as they look!
  • MrBuhl
    MrBuhl Posts: 2,419
    @F1nut, yep, they went in the afternoon they arrived! Still working on the burn in but so far I really like them. So far I've only about 20-25 hours of burn in on them, but they seem to have more low end punch than the previous tubes I've had in there.
    Still have that magical tube middle though. So far, that's the biggest difference I've noticed, is the bottom end, though there does seem to be an un-quantifiable descriptor, they just feel more lively, more complete, I don't really know how to describe it though!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
    F1nut Posts: 51,776
    Your description is spot on. You may notice swings in the sound quality as they burn in, don't be alarmed.
  • Mikey081057
    May take upwards of 80-100 hrs for them to get really sweet.
  • voltz
    voltz Posts: 5,384
    WTG ED!
    I got a quad set of Treasures from Darren for my Mc100b's.
  • Joey_V
    Joey_V Posts: 8,600
    Almost like chocolate in a chocolate box... So sweet I could almost eat them.
    Congrats!
  • leftwinger57
    leftwinger57 Posts: 2,917
    Not knowing a thing about tubes and peak performance could you answer this. The burn in time, is that under a load w/ tunes playing whatever the volume or just leaving them on as some do just as a practice of being a tube owner who leaves the amp,pre,phono amps on. The guy I bought my Dynaco from had ALL tube gear which I listed and he did not leave any tunes on and used when ready after an hour of warm up. His power amp was a Dynaco ST-70 w/o the cage and going into all other tubed gear.
  • MrBuhl
    MrBuhl Posts: 2,419
    edited October 2015
    Hey LW - I'm a relative tube noob, so others here may be a better source, but I am burning mine in the same way I do my speaks and cables, listening for the most part and also running them overnight with music playing. FWIW they basically stay on all weekend if I know I'm going to be listening, just off during the work week when I don't know if I'll have a chance. That's where the one-hour warm up comes in.
    While they are on a lot during warm-up I don't really count that as burn in time, assuming they need the dynamics of a signal to really get the burn-in process moving.
    I can tell you this, there's no doubt in my mind that they improve the longer removed from initial start up (warm up) they get, it's very noticeable the changes in musicality as things get good and toasty later in the evening. So that being said, I assume that having a signal running through them should be the process for burn-in as well.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • megasat16
    megasat16 Posts: 3,521
    edited October 2015
    MrBuhl wrote: »
    Tubes are being burned in the time they are powered up (i.e. the filament/heater lights up) regardless of music is passing through the tube or not. Plate current may not passed through the tubes if there is no music playing but the life on the tube is basically draining away as the filament is lit.
    All New Tubes should be completely burned in after 100 hours of heater light up time. Also, there should be little change in sound after the first 100 hours.
    Treasures made some nice tubes! I had KT-88 and CV-181 of Treasures and found them very pleasing.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
