LS 90 problem
My son said the speakers he has started to sound funny. So we went and pulled the grills to have a look. The piece, rubber?, that attaches to the metal is loose. Looks like the glue? that was used has failed. One is even separated from the cone I think. Looks like all of them are this way. So I guess I need to look for a speaker refoamer around here?
HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's
  • adam2434
    adam2434 Posts: 995
    Same issue as this?
    forum.polkaudio.com/discussion/159789/driver-for-ls90#latest
    If so, the same issue starting happening to my LS90 drivers last year - surround adhesive failure. I expect them all to start failing, as the surrounds easily peel from the cones and frames on the drivers with this issue.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • xjghost
    xjghost Posts: 1,115
    Yes. That pretty much is what is happening. I'll give Polk a call on Monday and see what they say.
  • Polkie2009
    Polkie2009 Posts: 3,834
    Happens to the best of them eventually . If you can't repair them, buy some used or new ones through Polk . Tell them you are a member and get a discount . :)
  • ken brydson
    ken brydson Posts: 9,063
    Weird, I've got 20 year old LS50's (purchaced new) and LS90's I got used with no signs of separation.
  • adam2434
    adam2434 Posts: 995
    Both of mine failed (one last year and one recently) with playing music fairly loudly. The music I was playing during the recent failure had a lot of bass energy from double bass being played on the track. So, I think it's high bass energy that causes them to eventually fail. When I heard a mechanical buzz the second time, I knew instantly that a second one had failed.
    On the failed drivers, the surround peels easily and cleanly away from the cone and basket. The adhesive remains bonded to the cone and frame, so it's the adhesive bond to the surround that's failing. Perhaps something from the rubber blooms over time to degrade the bond. I've only seen this type of failure on these LS90 drivers.
  • xjghost
    So which one of these numbers should I call?
    http://www.polkaudio.com/contact-us
    Service Center
    Tech Support
    Customer Service?
    pitdogg2 Posts: 27,597
    polk customer svc...Ask for Kim
  • xjghost
    Thanks he said to send in the drivers. Looks like I'm going to be packing up some drivers and shipping them to MD.
  • Polkie2009
    I had to replace one on my LS50's about 2 years ago and one on my LS90's a year ago. Both 50's and 90's use the same driver and I had bought some used ones before hand. took about 4 minutes to remove and instill the driver, E-Z ,P-Z. :)
  • xjghost
    I wanted to report back that I sent these in finally last month and had them rebuilt. Only charge was shipping to get them up there. Thanks Kim and Polk for standing behind your speakers. I reinstalled them and then hooked up the Parasound 1200ii I got on here to them and they sound great.
    Kudos goes out to Mr. Stills!
    Parasound in it's new home.
  • ken brydson
    edited December 2015
    NVM, different problem. Great CS right there.
  • xjghost
    No charge to rebuild them, just shipping?
    Yes.
  • xjghost
    nbrowser wrote: »
    mmmmm that's one sexy amplifier there... :)
    Even with a bent face plate curtsy the USPO!
  • DaveHo
    DaveHo Posts: 3,583
    That's some sweet customer service there. Way to go Polk!
