About to pull sl2000 and drop in rd0194 on crs+
are there any pointers I should be aware of or will this be a true, easy 'drop in' replacement? Thank you in advance. What's everyone's burn in experience? Much appreciated.
    F1nut Posts: 51,783
    Straight swap. Takes about 50 hours to fully cook.
  • Rex81
    Rex81 Posts: 193
    Easiest upgrade you can do. Just make sure you note which wire is positive and hook it onto the post that's painted red on the new tweeter.
  • elitt
    elitt Posts: 162
    edited September 2015
    wow. just wow. i guess i could post in another rd0194 thread but i don't want to hijack. if these only improve with hours i cannot wait for them to pass. what a sweet upgrade. i'm inspired to tackle the crossovers now.
    i've had 5j+ since the mid 80's and 7's with peerless following, but i've been chasing these crs+ for years. it's inspiring me to get back to music they way it used to be in my life.
    ps - i hooked the black lead to the red post - if that's not right i'm in for a real treat!
  • cortico
    cortico Posts: 587
    The black is the positive, you got it!
  • soundfreak1
    soundfreak1 Posts: 3,414
    The 194's made quite a different in my 12c's, enjoy. Have you dynomated the driver baskets yet?? If not your in for another treat with another simple mod.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • elitt
    elitt Posts: 162
    I haven't, and haven't found a tutorial thread yet. Can you point me in the right direction?
  • motorhead43026
    motorhead43026 Posts: 4,012
    edited October 2015
    Use the search feature, you will find a wealth of information.
    And it is dynamat.
    – Kevin Alfred Strom
  • soundfreak1
    And it is dynamat.
    Fat thumb syndrome!
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • Wasn't correcting you, just figured the new guy using the lousy search feature dyno wouldn't turn up anything.
  • soundfreak1
    No harm no foul, i spell ok just cant type worth a crap. LOL
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
