Polkaaudio series 2 speakers
A client of mine was moving and graciously gave me a polka surround speaker set. Too big to lug around anymore, he said. They say Polkaaudio monitor series 2 on the big speakers. There are actually 5 satellite, 1 subwoofer ? and 2 floor speakers with stand. Now I need to go out and purchase a receiver for them but I cannot find any specs on them: impedence, watts per channel. Where would i find this stuff and what receiver shoulfd i get that would match the speakers?
Jeff
    pitdogg2 Posts: 27,064
    well if you could give us more info we could help more. there should be model numbers on them somewhere.
  • Hi Pitdog2,
    I looked all over them and the only thing I found was a bar code on one of the larger speakers: M10 9007701
    and the words Polkaudio Monitor Series 2.
    They are black and super heavy and the 2 satellite speakers and subwoofer are without labels.
    Jeff
  • dkfreebird
    dkfreebird Posts: 1,186
    Sounds like you have the Monitor 10 series 2 with factory stands maybe.Size of stands and speakers will help as well as pics.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • boston1450
    boston1450 Posts: 7,758
    edited September 2015
    Monitor 10's are very nice speakers. Keep above 50wpc to 200wpc. Are you looking to do 2 channel music or 5/1 or 7/1 ? What do you do mostly = Music % Movies. Those speakers will match well with Marantz Sansui Yamaha Denon Harman Kardon & many more. Do you want a powered subwoofer & what is you budget ? You can buy local 5/1 receivers all day long for 50.00 up.... If you have a decent budget go with a receiver that you can add a amp LATER ON for the front speakers
    Post edited by boston1450 on
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • motorhead43026
    motorhead43026 Posts: 4,012
    Yep, monitor 10 series II, circa 1990. Do yourself a big favor and drop in a set of the RDO-198 tweeters. Your ears will thank you.
    – Kevin Alfred Strom
  • Okay, great to know they are fine speakers. My teenage son does abit of gaming but music and movies would be the main use. we are mac based and have misogynistic on iPhones. would be fun to spin some records too. Sounds like the speakers are good enough to build on. I will need a5-1 receiver, 1 guess as there are 5 speakers.Can I get a decent one on Amazon for around $250? Last system I owned was a stereo with an 8 track and lots of pretty lights, so I am definitely on a steep learning curve here. Any suggestions much appreciated
  • When you do start looking skip the middle of the road stuff. Get a decent AVR such as Yamaha Aventage or Pioneer Elite you will thank me later.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • A $250.00 new receiver will be a waste of $250.00.
  • Jimbo18
    Jimbo18 Posts: 2,349
    Motorhead is right. My first receiver purchase was the Yamaha RX-V373 and it was right around that price new. Specs look good for power but in reality it's way too low to really get everything out of it. Unfortunately, I wasn't using this site for advice before I bought it.
    If I had, I would have checked out accessories4less as many here suggest.
    http://www.accessories4less.com/make-a-store/category/avreceiver/home-audio/receivers-amps/home-theater-receivers/1.html
    Find yourself one that has preouts so you can add an external amp later if you want.
  • rooftop59
    rooftop59 Posts: 8,121
    edited October 2015
    I have one of these little Marantz's, and it sounds really quite good, especially with an external amp driving the mains (which is what you will eventually want to do). And don't let the 50 wpc scare you, they are honest watts and warm great synergy with Polks.
    The good thing about those Polks is that they are easy to drive, so the marantz could do fine until you save up for an external amp:
    http://www.accessories4less.com/make-a-store/item/marnr1403/marantz-nr1403-slimline-5.1-av-receiver/1.html
    Congrats and have fun!
    Game Room 5.1.4:
    Bedroom 2.1
  • This is all really good stuff folks! accessories4less will save me heaps. Good buy Amazon, pun intended.
    Looks like $250.00 is at the low end and $600 is the sweet spot for getting it all in an avr. However, that Marantz which is really discounted should do it for my small rooms in this 900 ft. home. Nice recommendations
    A couple questions:
    Can you buy a 7.1 avr and just run 5 speakers on it and add speakers later on , or is that just not done?
    Is the external amp just to make the system louder or does it allow you to add better speakers later on, or helps push air into a larger room. Preouts a must but why?
    How do I ensure that the avr and the Monitor 10s are matched in impedence )ohms)?
    I cannot find a spec sheet on the Monitior 10s out there on the web. i do have a multimeter somewhere. Is it a simple matter of hooking it up to the ports on the back of the speaker?
    Here are pics as requested to ensure they are tens.
  • Found the specs for many vintage Polka speakers at this link:
    https://us.v-cdn.net/5021930/uploads/attachments/4/7/5/0/2/53135.pdf
    Here are the ones specific to my speakers:
    Monitor 10 Series 2
    1990 $740
    Subwoofer 1 - 10" Diameter (25.40cm) sub bass radiator
    Midrange 2 - 6-1/2" Diameter (16.51cm) drivers
    Tweeter 1 - 1" Diameter (2.54cm)
    Polk SL2500 dome tweeter
    Overall Frequency Response 25Hz - 25kHz
    Lower -3dB Limit 37Hz
    Upper -3dB Limit 23kHz
    Nominal Impedance 8 ohms
    Recommended Amplifier Power 20-250 w/channel
    Efficiency 89 dB
    Dimensions Cabinet Size 28" H x 15" W x 12" D
    Shipping/Other Total Shipping Weight 46.00 lbs.
  • Yep, monitor 10 series II, circa 1990. Do yourself a big favor and drop in a set of the RDO-198 tweeters. Your ears will thank you.
    Where does one find these tweeters? I would like to get them so i can thank you later.
  • George Grand
    George Grand Posts: 12,258
    Oh yeah, that's the ticket. Upgrade to SDA as soon as possible, in fact, sell all the Polks you just got to fund the purchase of a pair.
    Does anyone read? His last receiver had an 8-track player stuffed in it.
