Monitor 7b woofer pop
Hi my name is Bob and I am new here. I bought a
Pair of Monitor 7b's and I'm using a Marantz reciever and the woofers are popping. The receiver is rated
at 52 watts. Is this a common issue.
  • Nightfall
    Nightfall Posts: 10,084
    How loud do you have it turned up if the volume dial is a clock? Past 11 o'clock?
    How much is the bass turned up in the tone controls?
    Does it have a "loudness" button and are you using it?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Yes. Past 11 bass maxed and loudness on.
  • Nightfall
    MORONGOBOB wrote: »
    My spidey senses are tingling...
    afterburnt wrote: »
  • Sorry I'm pretty new at Vintage audio. I still expect all speakers to sound like a subwoofer. The 7b's do sound very awesome.
  • Nightfall
    Benefit of the doubt...
    Get a subwoofer with high level inputs, bypass tone controls, turn off the loudness switch, and keep the volume below 11 o'clock.
    afterburnt wrote: »
  • BlueFox
    BlueFox Posts: 15,251
    MORONGOBOB wrote: »
    Why?
    gudnoyez Posts: 8,159
    Sounds like you need a pair of Cerwin Vegas. That is if you like it loud and a over emphasis on the Bass, or turn it down a bit and ease off the tone controls hopefully you haven't done any damage.
    txcoastal1 Posts: 13,502
    gudnoyez wrote: »
    Even Cerwin Vegas won't give him justice on 52watt Marantz...somethings going to blow
  • Sorry about that Bob, but I think you might have to learn the hard way.
  • Blown equipment and ear drums so be it, I am not impressed.
    – Kevin Alfred Strom
  • halo71
    halo71 Posts: 4,630
    Poor speakers......
    --Gary--
  • PolkieMan
    PolkieMan Posts: 2,446
    Even if it is still able to output 52 actual watts in it's twilight years you may be over-driving/clipping it, causing it to loose any damping that it has at normal volumes and with the bass set for a more natural sound
