Marantz AVR Popping and going into protect mode.
hochpt21
hochpt21 Posts: 5,423
edited September 2015 in Electronics
I just got a used Marantz 6004 AVR.
I have a BR player and a cable box input, and one output to my projector. The front three channels are pre-out to an amp and the side two are run off the AVR. I used this configuration with a Sony AVR with no issues.
Last Sunday, I watched football for over 5 hours with no issues. Throughout the week we have watched 30 to 60 minutes at a time with no issues.
Today, I ran Audyssey. Everything seemed to work great and the settings seemed good. But since I ran audyssey...every 20 minutes, I hear a loud pop from all the speakers and the AVR goes into protect mode. This happened four times, then I just shut the unit down.
The AVR stays off for around 30 seconds and then clicks back on like everything is normal. The last time it happened I was listening at volume that I could barely hear, so I'm definitely not pushing the unit at all. Plus like I said...the front three channels are amped up.
What could be the cause?
Why would running Audyssey have anything to do with this?
Please help!!!
Paul
  • mikeyb128
    mikeyb128 Posts: 2,885
    This happened to me with a pioneer elite receiver. what tech support told me was that because I didn't have the front 3 amp sections turned off the AVR was seeing a blown speaker and was going into protect mode. I turned the front amp sections off and never had an issue again. Not sure if marantz is the same but maybe it's something to look into.
    2 channel:
    Theater:
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    I had an Onkyo 705 that would get terribly hot when audyssey was on, if I left it on it would eventually go into protection. Never was able to solve the problem.
  • hochpt21
    mikeyb128 wrote: »
    Thank you, I will see if that is an option.
  • hochpt21
    It was a little hot, but doesn't audyssey turn off after I run the set up? Or am I not understanding it correctly?
  • No audyssey is digital processing, it eq's digitally. Analog sources are converted to digital, processed then converted back. You can have audyssey set levels and distance, then turn it off.
  • hochpt21
    Ok, just turned the unit back on and Audyssey was on. I just turned it off, so we'll see how it goes.
  • hochpt21
    So if I turn the Audyssey off, the distances stick?
    Or only when the the audyssey is on?
    Am I missing a big benefit by having to turn it off after the distances are set?
  • Yes the distance and levels remain, as far as benefits go having audy eq or not is just preference.
  • hochpt21
    Thank you very much.
