Damn it....DSW Pro 600 No Worky!
It powers up, but the green led on the back next to the auto/on/standy switch quickly goes to red even when there is a signal being sent. I double checked vs. my 15" Epik, which rocks by the way, and it indeed is the DSW pro. So, what am I supposed to do with this thing?
  • rpf65
    rpf65 Posts: 2,127
    I would try the switch set to on first, and see if that works. Then a different power cable, simple because I would be to lazy to check the iec wire. If none if those work either a new amp, or turn it into some kind of shrine or planter.
  • kevhed72
    kevhed72 Posts: 5,247
    What a bunch of crap....I am fearing the worst just when Im trying to buy a new integrated. This thing is only 7 years old or so. I bet the amp is blown....do subs have fuses inside?
  • rpf65
    rpf65 Posts: 2,127
    Newer ones on back, exposed. Older ones not sure, could be one internally.
  • drselect
    Nope no fuses. Pop the hood and see if you got ooz all over. Thats what happened to mine.
  • kevhed72
    I hooked up the 15" sealed Epik to the HT in the mean time. I always assumed a ported, smaller sub was the way to go for a smallish HT room - which is maybe 16 x 20 . Man, was I wrong. This Epik crush the DSW and brings the whole HT system to a higher level. Regardless of room size, to a point, try to go with the largest sub you have room for.
  • [Deleted User]
    Hello,
    I'll send a copy of this thread to Kim at Polk CS, maybe there's something he can do to help.
    Sorry you're having a problem.
    Ken
