Polk RTA-11TL speakers
One of the tweeters (SL3000) is out but I have two silver coil replacement tweeters. Will they work OK?
Best Answers
    EndersShadow Posts: 17,705
    Answer ✓
    If they are not SL3000 or RDO198 they will "work" but not be the correct match
  • boston1450
    boston1450 Posts: 7,758
    Answer ✓
    Be a good time to change them both out to 0198's
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
Answers
  • Great. Thanks for your advice.
  • boston1450
    edited September 2015
    When i did swap them out. I took 1 out & listened for a few min's (just to see if it was true what everyone says). I noticed a big difference even with my old ears & i shut it down & put the 2nd one in quickly & listened to them for hours. Sounds very good. I noticed they were clearer & stood out better & chimes n bells were so much better. The 3000's are not that bad BUT if you have one gone-why not upgrade. Perfect time to do so & if your gonna keep the speaker its well worth ''Calling'' Polk & tell them your a Forum member & they will give you a discount :) Enjoy those 11's & welcome to CPolk
    Randy-Maine
    by David WMG
