DVD Players
edited March 2004 in Electronics
I've read a few discussions about good DVD players and need some help. I need to upgrade my old Sony to something much better. It seems that you guys like the Denon 2200/2900. Can someone name a few in the $300 range (new or used) that really perform well. Thank you.
Main-RTi150
Rear-FX500i
Cntr-CS245i
Sub -PSW202
Amps-?
Pre-Pro-Adcom GTP-760
Post edited by slyreb on
Welcome!
    edited March 2004
    As far as specific models, it really depends on what you want. Do you want DVI output? Do you want a universal player? Do you want a multi-disc player? do you want better video or better audio? Lots of variables to consider!!!!
    Rocky Bennett
    edited March 2004
    Denon 910. Kicked butt in the Secrets benchmarks.
    edited March 2004
    You got a link to the benchmark test...? Thanks.
    "God grooves with tubes."
    edited March 2004
    Go to hometheaterhifi.com and look for the DVD player benchmarks list. Its a huge list, they check all the dvd players for alternating flag problems, both chroma problems, layer change times, etc. I like their technical approach to testing. They don't get all artsy fartsy, they just tell you what works and what doesn't.
Welcome!
Welcome!
